Bought 2 Switches, Which To Use, Wire
Old Dec 29, 2003 | 02:18 PM
another_crx's Avatar
Default Bought 2 Switches, Which To Use, Wire
For Fuel Pump Cut Off Switch
Went to Radioshack to grba a switch and got 2 for free because my friend works there. I dont know which one I am using or hwy there are 3 prongs.
First heres info on the 2 switches:
(exactly as on package)
1.Illuminated Auto Rocker Switch
Part#275-712
12 VDC/VCC 30A
2.Automotive Rocker Switch
Part# 275-731
25A to 12VDC
Now which one would be best? I dont know anything about those codes.
Also they both have 3 prongs on bottom, I thought there would just 2, for both incoming wires, is the last for a ground?
Why would I need a ground? How exactly would I ground such a small *** wire?
Old Dec 29, 2003 | 08:50 PM
Default Re: Bought 2 Switches, Which To Use, Wire (another_crx)
up
Old Jan 2, 2004 | 05:13 PM
dax-es's Avatar
Either of the switches should work, so pick the one you like best. The guide below has the switches listed and the way they're connected. The two you listed are SPST. The third prong is most likely used to illumination the switch.
http://www.radioshack.com/imag...1.pdf
Old Jan 3, 2004 | 12:35 AM
nsxxtreme's Avatar
Default Re: Bought 2 Switches, Which To Use, Wire (dax-es)
Look up the datasheet for each or request it from the manufacturer. Use the one with the highest MTBF
turbo-crx
Jan 9, 2009 09:58 AM
fryman
Audio / Security / Video
Jul 27, 2008 04:27 PM
civicexowner
Dec 22, 2007 04:04 PM
FGride
Apr 26, 2006 12:43 AM
Simple
13
Jan 10, 2004 07:57 AM
