Boost controller - arming alarm lights not on
Before when I used to arm my alarm, my headlights/taillights would blink.
After a Boost Controller install today, I noticed that when I armed my alarm the headlights/taillights did not blink??
The headlights still work.. What could be the possible problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j boy »</TD></TR><TR><TD CLASS="quote">Before when I used to arm my alarm, my headlights/taillights would blink.
</TD></TR></TABLE> The parklight ,[ and you should use parklights, not headlights ] output of the alarm is disconnected or the fuse is blown on that output.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> The parklight ,[ and you should use parklights, not headlights ] output of the alarm is disconnected or the fuse is blown on that output.
94</TD></TR></TABLE>
thanks for the reply!
where could i possibly check for this blown fuse?
94</TD></TR></TABLE>thanks for the reply!
where could i possibly check for this blown fuse? </TD></TR></TABLE> On most alarms there is a fuse right on the parklight wire, 5 or 6 inchs from the alarm brain, and if wired properly, it will be plugged into the parklight freeplug on the fuse box, and on a lot of alarms the wire is white.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> On most alarms there is a fuse right on the parklight wire, 5 or 6 inchs from the alarm brain, and if wired properly, it will be plugged into the parklight freeplug on the fuse box, and on a lot of alarms the wire is white.
so you think most likely a fuse is blown?
94</TD></TR></TABLE>so you think most likely a fuse is blown?
so you think most likely a fuse is blown? </TD></TR></TABLE> Well if the lights all work and the alarm works, then its a fuse, or its disconnected, or
the parklight output of the alarm is toast
94
94
YellowPhoenix095
Audio / Security / Video
May 2, 2008 02:02 AM
