best sub box for hatchback....
Old Feb 8, 2006 | 06:55 PM
shyboi4u's Avatar
Default best sub box for hatchback....
the vented box or the sealed box? which one would be best? i'm planning on puttin one 10 in my EH2 (EG6).
Old Feb 8, 2006 | 07:07 PM
skrewdriver88's Avatar
Default Re: best sub box for hatchback.... (shyboi4u)
What kind of music do you listen too? Do you want your bass to be boomy or clean
Old Feb 8, 2006 | 07:23 PM
shyboi4u's Avatar
Default Re: best sub box for hatchback.... (skrewdriver88)
listen to r&b/rap, alternatives, and pop. i like my bass to sound deep and i also like to bass to fade out. you know what i'm talking bout?
Old Feb 8, 2006 | 07:29 PM
shyboi4u's Avatar
i've had a 2 10" bandbass box before. sounded good. then i got a sealed box and it sounded cleaner. now i'm going for 1 10". so i now i'm wondering bout the vented box, the ones with the long rectangular port. so now i'm wondering which one would be better vented or sealed?
Old Feb 8, 2006 | 07:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
What kind of sub are you going to use?
Old Feb 8, 2006 | 08:59 PM
shyboi4u's Avatar
Default Re: (wrx-killer-Sti eater)
either a JL w6 or alpine type E.
Old Feb 8, 2006 | 10:05 PM
shyboi4u's Avatar
Default Re: (shyboi4u)
c'mon, where are the experts at?
Old Feb 9, 2006 | 07:54 PM
suspendedHatch's Avatar
Give it a couple of days, ****. This forum moves slow.
Old Feb 9, 2006 | 08:02 PM
HondaEJ7's Avatar
my buddy has a ported box in his 95 talon. sounds great. sealed is good for cars with trunks, like a civic coupe. vented would work alright too, but id go with ported if u can, if not, vented.
Old Feb 9, 2006 | 08:51 PM
shyboi4u's Avatar
Default Re: (HondaEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">my buddy has a ported box in his 95 talon. sounds great. sealed is good for cars with trunks, like a civic coupe. vented would work alright too, but id go with ported if u can, if not, vented.</TD></TR></TABLE>
i though it was the other way around. sealed for hatch and ported for trunks. the vented is suppost to make the bass deeper..
Old Feb 10, 2006 | 12:06 AM
Sealed and ported boxes can go into any car. It does not make a diffrence. Ported boxes play more acurate and ported or vented play about 3 db louder then a sealed and give you more spl. Now if you have a trunck like a civic or accord do something like this, I built this for my sister car.
Its a bandpass thats ported into the car, Whats good about this is that there is no trunk rattel. The bass is injected into the car. Down side is that it will blow the rear window out. Only when tuned for max spl. And you don't need alot of power. so it helps stay low budget. But on some songs it lacks real low end. Don't get it twisted. it can go low but not like a sealed box. If I was you go with a sealed. It will save you space. and knock because it a hatch. Hatches have great cabin gain. If not get the ported and have greater spl. Also remember sealed boxes require more power to opperate then a ported. a ported can uses less power then a sealed box to work.
Old Feb 10, 2006 | 12:12 AM
shyboi4u's Avatar
thanks, thats good info....and then some...nice box..looks clean...
Old Feb 10, 2006 | 07:14 PM
vc's Avatar
vc
Default Re: (B18 EH2)
10W7
Old Feb 10, 2006 | 10:16 PM
MinuteRice's Avatar
Default Re: (vc)
It matters what kinda music you listen to. If you listen to a lot of rap/hip-hop go with the ported box, if you listen to rock or other stuff go with the sealed box. would diffently go with the JL audio W6 it will sound good in a sealed or ported box. I would go with the sealed, you don't need the extra output that a ported would give you. Just make sure that whatever box you get it's built spec for the sub it will make all the difference, if you go with the wrong size ported box it can make the sub sound real bad and might cause possible damage to the sub. The right size box makes the sub
Old Feb 11, 2006 | 01:14 PM
panickid666's Avatar
Default Re: best sub box for hatchback.... (B18 EH2)
how do u get ur license frame from rattleling ???
Old Feb 11, 2006 | 04:17 PM
drkblue_civic's Avatar
Default Re: best sub box for hatchback.... (panickid666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panickid666 &raquo;</TD></TR><TR><TD CLASS="quote">how do u get ur license frame from rattleling ???</TD></TR></TABLE>
dynamat pick it up at a local shop ten bucks
Old Feb 13, 2006 | 07:30 AM
Default Re: best sub box for hatchback.... (drkblue_civic)
Take off the license plate, get some plyers and a rag, bend the mounting holes so that the plate will sit tight against the car, reinstall.
Vtecfool
Audio / Security / Video
12
Jan 4, 2004 05:30 PM
loki2323
Nov 10, 2003 12:06 AM
'89 hatch
Jun 11, 2002 04:29 PM
redteg1
May 16, 2002 05:33 PM
GoLowDrew
Jul 28, 2001 09:52 AM
