Best amp wireing package?
Old Dec 23, 2005 | 10:18 PM
sagron69's Avatar
Default Best amp wireing package?
I've got an Infinity Reference 4-channel amp (the 7541a) and i'm going to be hooking up the kappa perfect 6.5 components and the kappa 6x9's. which is the best amp kit to get. My friend works at CCity, and i was planning on getting the "tsunami 1200 watt amp kit" if that'll be a good set up then let me know, if not give me your opinions. Thanks.
Old Dec 24, 2005 | 08:05 PM
aeon's Avatar
knukonceptz.com has some good wiring kits. Just buy a 8 gauge wiring kit that is within your budget and for a 4 channel amp. No need to buy those expensive wiring kits like the rockford.
Old Dec 24, 2005 | 09:14 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Get the tsunami. Trust me, you will be getting a good kit. Some of thoses kit out there are junk. Look at the tsunami wire and look at the cheaper wires. Lets use 4 gauge as a example. I have tsunami and streetwire at my shop, I also have thoses cheap kits at my shop as well. when you compare the two you will see the diffrence. The good cable is true 4 gauge and the cheaper one is 8 gauge with coating of a 4 gauge wire. you pay for what you get. Get the tsunami. don't waste your money.
Old Dec 24, 2005 | 09:24 PM
sagron69's Avatar
Default Re: (wrx-killer)
thanks guys i appreciate all the input... i'll be pickin up the tsunami later on this week... and here's another question to you uber installers... i'm trying to figure out where to hid the component cross-over box thingy when i'm installing my 6.5s in the front... it's huge and i'm afraid i wont be able to find a place to justify an install... by the way it's a 99 civic si that it's coming into (coupe)... thanks in advance
Old Dec 24, 2005 | 10:10 PM
Cobb2819's Avatar
Default Re: (sagron69)
dang guys, 2 great options right off the bat. tsunami kits are great if you're looking for an in one box option, if you feel like piecing together a kit, KnuKoncepts stuff is awesome power wire and accessories, and then just use tsunami 10.# series cables.
Old Dec 25, 2005 | 01:43 AM
sagron69's Avatar
Default Re: (Cobb2819)
thanks again... i'll stick with the package, but the piece by piece i think i'll use on my buddy's car... he's doing subs also. bump for the second qestion though
Old Dec 26, 2005 | 09:51 AM
you can put them in the door if you like, wrap them in a plastic bag and tape of the opening. them put couple of small holes for it to breath. that work. Or you can pull two speaker leads into the door. good luck
Old Dec 28, 2005 | 10:43 PM
sagron69's Avatar
that sounds like a good idea... any other suggestions?
EvenStar
Audio / Security / Video
10
Jan 25, 2007 07:55 AM
BIntegra99
Aug 11, 2005 05:37 AM
pezzy
Sep 15, 2004 09:25 PM
HondaGuRu
Jun 12, 2003 11:44 PM
MeKKa301
Oct 16, 2002 07:37 PM
