backup siren install?'s
How do I install my backup siren w/ internal batt.? Red(+) black (-) but what do i do with the other 2 wires, white (+) trigger and blue (-) trigger? Do I splice them into my current siren wire. my current siren wires are 2 gray wires stuck together. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goofball123321 »</TD></TR><TR><TD CLASS="quote">How do I install my backup siren w/ internal batt.? Red(+) black (-) but what do i do with the other 2 wires, white (+) trigger and blue (-) trigger? Do I splice them into my current siren wire. my current siren wires are 2 gray wires stuck together. Thanks.</TD></TR></TABLE> If you want the backup siren to also go off with the alarm, then yes, you need to know if its a ground or positive that drives the siren, or if the alarm has an alarming out, [ a trigger + or - only when the alarm is tripped NOT when arming or disarming]
94
94
i actually have the same back up siren. and im also wondering how to install it with out tapping into my current alarm system? is this possible? i dont mine buying additional switches. dont mean to hi jack the thread just topic related
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5lugNinja »</TD></TR><TR><TD CLASS="quote">i actually have the same back up siren. and im also wondering how to install it with out tapping into my current alarm system? is this possible? i dont mine buying additional switches. dont mean to hi jack the thread just topic related
</TD></TR></TABLE>You do not have to wire the backup siren to the alarm system, just wire up the power and ground, if cars batt. is disconnected, the backup siren will trip, that is why they call it a backup siren.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">You do not have to wire the backup siren to the alarm system, just wire up the power and ground, if cars batt. is disconnected, the backup siren will trip, that is why they call it a backup siren.
true, but once you reconnect to the battery the back up siren will go back to off mode. is there any way into making the siren sound and quirp until you hit a hidden switch or insert the key located on the back of the siren? that way once they disconnect the battery the back up siren will sound and chirp even if they reconnect the battery back on.
</TD></TR></TABLE>true, but once you reconnect to the battery the back up siren will go back to off mode. is there any way into making the siren sound and quirp until you hit a hidden switch or insert the key located on the back of the siren? that way once they disconnect the battery the back up siren will sound and chirp even if they reconnect the battery back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5lugNinja »</TD></TR><TR><TD CLASS="quote">true, but once you reconnect to the battery the back up siren will go back to off mode. </TD></TR></TABLE>
Most alarms go off when power is reconnected.
true, but once you reconnect to the battery the back up siren will go back to off mode. is there any way into making the siren sound and quirp until you hit a hidden switch or insert the key located on the back of the siren? that way once they disconnect the battery the back up siren will sound and chirp even if they reconnect the battery back on. </TD></TR></TABLE>If you want the BBS to chirp when you arm and disarm the alarm and go off when the alarm is tripped, you will need to wire it to the alarm, using the - or + input to the BBS, it will still trip if batt is disconnected, unless turned off
94
94
noworldorder
Audio / Security / Video
Feb 28, 2007 06:43 PM
