Antenna Half Mast Switch Help
I wasn't being "hostil", whatever that means...
I was inquiring if the unit came with directions? Maybe they're in Japanese and you can't read them?
Then, I suggested that you obtain a service manual for the car the part came out of. Surely the information you seek is contained in that manual.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russianswty »</TD></TR><TR><TD CLASS="quote">I think but im not sure that you actually need the whole antenna with motor. (jdm one)</TD></TR></TABLE>I don't know how else you can do it, the 1/2 way up limit switch is in the ant., not the switch.
I guess you could build a timer module for the USDM power ant.
94
PS, you could make it "manual" 1/2 way up, install the switch on the ant. constant power lead and just turn it off when ant. is where you want it, can't see any other way with just a switch.
94PS, you could make it "manual" 1/2 way up, install the switch on the ant. constant power lead and just turn it off when ant. is where you want it, can't see any other way with just a switch.
Thanks for bringing back a thread that's been dead for 4 months...
JDMTEG98
Sep 1, 2002 07:04 AM
