Antenna doesn't work after new head unit installed
I remember whenever i turned my deck on in the past with my stock deck, the antenna would always go up. Now with my aftermarket deck, it doesn't go up at all. I have a pioneer deh-3100 if that helps any. When the deck was in my civic, i didn't have the blue/white wire connected to anything, so i did the same to my integ. Am i doin anything wrong?
you have to hook up the blue/white wire, it says POWER ANTENNA on it just go ahead and hook all 3 blues up together, that'll fix your problem, civics dont have power antennas so they dont need that wire hooked up, but teggies do, so it needs to be hoooked up yo
yes if u used a wiring harness to hook up ur radio it should only have one blue wire, hook that up to the pioneers ant/remote wire and you are good to go. If you are also connecting an amp connect them together with those two wires is what i think he meant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW »</TD></TR><TR><TD CLASS="quote">yes if u used a wiring harness to hook up ur radio it should only have one blue wire, hook that up to the pioneers ant/remote wire and you are good to go. If you are also connecting an amp connect them together with those two wires is what i think he meant
Thanks guys, i finally got it. Its nice to hear the radio now
</TD></TR></TABLE>Thanks guys, i finally got it. Its nice to hear the radio now
kelviiv
Audio / Security / Video
Jan 15, 2009 12:28 PM
94B18B1Teg
May 11, 2004 05:44 PM
