Antenna Adapter
Old Mar 19, 2010 | 11:55 AM
grape1161's Avatar
Default Antenna Adapter
I bought a VRVD630 to put in my 93 Si, and the antenna will not fit into the spot on the radio, the antenna plug is larger than the hole. Where would I be able to find a adapter for it besides Radio Shack ? I called them to see, and all I got from them was "Uh, Uh, Uh?" Any help would be greatly appreciated on this
Old Mar 19, 2010 | 12:04 PM
red92si's Avatar
Default Re: Antenna Adapter
You could always cut off the old antenna lead and wire it onto the new antenna's wire.
Old Mar 19, 2010 | 06:15 PM
jason0123's Avatar
don't cut your antenna wire. Because when the radio breaks (and it will) you may not be able to return it.
Old Mar 19, 2010 | 08:46 PM
baller status's Avatar
I don't know what a VRVD630 is... very few Hondas require an antenna adapter. And no Civics need them so I don't know what your issue is... but Best Buy has the Honda antenna adapters if you need them. You can look up the part number on Metra.
Old Mar 20, 2010 | 09:04 AM
fcm's Avatar
fcm
Old Fart
Also do not know what a VRVD630 is?
A pix of ant. plug/port would help. 94
Old Mar 20, 2010 | 07:18 PM
grape1161's Avatar
It's a CD/DVD/MP3/USB/SD Card player. I can't find any pics for it, but the Antenna outlet looks normal, but the Antenna plug is too big for the hole.
Old Mar 20, 2010 | 08:39 PM
fcm's Avatar
fcm
Old Fart
Then it could be a "mini Motorola", used on newer GM vehicles, [maybe HU was designed for a Chevy, you need one of these...
http://www.scosche.com/products/productID/205
Also avalable from Metra and AI and Best. 94
Salvi-EJ1
Jul 5, 2012 08:34 PM
97teg415
Audio / Security / Video
Sep 20, 2007 07:30 AM
sixtodc2
Oct 1, 2006 10:47 PM
mooseheads36
18
Apr 25, 2006 03:03 PM
Julian
Jul 26, 2002 01:13 PM
