anither DIY alarm problem
Old Jul 17, 2008 | 04:19 PM
delsol456's Avatar
Default another DIY alarm problem
i just installed a viper 5002 into my 94 del sol. the siren is allways going off, but the alarm wont arm or disarm, nor will putting the battery terminal on with the keys in the ignition help. the indicator on the remote indicats disarmed but the siren is just going off.
the siren is grounded, and the brown from the brain is going 2 the red wire on the siren. somebody please help!
Modified by delsol456 at 9:49 AM 7/19/2008
Old Jul 17, 2008 | 05:16 PM
delsol456's Avatar
Default Re: anither DIY alarm problem (delsol456)
this tread moves slow.
-update-
when ever i get nere the car my remote beeps and vibrates in the dets of two. (beep beep....beep beep...beep beep) i can put it into valet mode. but thats about all it does.
Old Jul 17, 2008 | 11:37 PM
neozero999's Avatar
this is what i did when i installed my alarm. disconnect the horn so you have no noise, then re check ALL your wiring like the big basics ground for brain 12v+ constants, parking lights etc. now since you have the horn disconnected and when you go near the car or whatever you do to set off the alarm you can mess with it. your parking lights flash right when the alarm is triggered?
Old Jul 18, 2008 | 11:15 AM
delsol456's Avatar
Default Re: anither DIY alarm problem (neozero999)
no lights flash when the alarm is going off. i dont know if its actuly the alarm or just the siren going off.
Old Jul 18, 2008 | 12:23 PM
delsol456's Avatar
ok everything works the way it should, except thet the fact that tha siren is always going off.( not the alarm, just the siren) can some one verify where the orange (ground when armed) wire goes on a viper alarm. its an extra feature right?
Modified by delsol456 at 4:39 PM 7/18/2008
Old Jul 18, 2008 | 04:58 PM
fcm's Avatar
fcm
Old Fart
You have either miswired something or the alarm is defective.
The orange, ground out when armed can be used for extra "kill" relays. 94
Old Jul 18, 2008 | 07:00 PM
delsol456's Avatar
Default Re: anither DIY alarm problem (fcm)
ive yet to actually wire the kill, which is its own separet harness. this wouldnt cause ne problems would it? and when ever i disconnect the ground or positive for the siren the remote n brain dont communicate. is this normal? i guess ill pull the all the wires out n start all over..
GATASboy
Audio / Security / Video
Aug 17, 2009 08:24 PM
pdd
Honda Civic (2001 - 2005)
Jul 28, 2007 09:50 AM
200k mile sol
May 19, 2006 07:33 PM
dukers
Jul 18, 2005 05:39 PM
Xerxes3333
Mar 3, 2004 08:47 PM
