Amp to Power Alpine Type R Sub
Old Oct 14, 2003 | 05:56 AM
teg88's Avatar
Default Amp to Power Alpine Type R Sub
What amplifier is best to power a 12" Alpine Type-R Sub?
Old Oct 14, 2003 | 02:56 PM
Torridcivic's Avatar
Default Re: Amp to Power Alpine Type R Sub (teg88)
Price range? Is it a DVC? do you want a class d (effiecient) ? Amp or does it matter?
Old Oct 14, 2003 | 07:41 PM
JustinL's Avatar
Default Re: Amp to Power Alpine Type R Sub (Torridcivic)
id like to get an american bass mono 1000 watt amp cause they are badass
Old Oct 15, 2003 | 10:46 AM
teg88's Avatar
I want to spend as little as possible without sacraficing safety or too much performance.
New Or Used Amp.
Yes it is DVC.
Any suggestions please?
Old Oct 15, 2003 | 12:03 PM
EBP_SI's Avatar
Default Re: (teg88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg88 &raquo;</TD></TR><TR><TD CLASS="quote">I want to spend as little as possible without sacraficing safety or too much performance.</TD></TR></TABLE>
still doesn't help too much. give us an actual number.
Old Oct 15, 2003 | 02:37 PM
ll kaidoy ll's Avatar
i use an Alpine MRD-m500 v12 amp...@ 2 ohms, 500 watts RMS x 1 and 900 watts max x 1
Old Oct 15, 2003 | 09:45 PM
TurboBumblBee's Avatar
Default Re: (ll kaidoy ll)
mtx thunder801d is a badass amp for that sub as well.. im sure there is better but for the money you can beat it.. ive heard this amp and sub together and it sounded very clean...
Old Oct 16, 2003 | 05:27 AM
teg88's Avatar
Umm...I know nothing about amps so I don't want to sound cheap but I want to spend between $100-130 new or used.
Old Oct 16, 2003 | 06:44 PM
Xsi's Avatar
Xsi
The old Alpine MRV 1005 is a great amp, you could probably pick one up pretty cheap second hand
Old Oct 16, 2003 | 10:52 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Is it a DVC and what ohm's is it? If its a 2 ohm DVC then you'll need a amp that'll put out about 400watts rms at either 1 or 4 ohms. If its a 4 ohm DVC, you'll need a amp thats rated at 2 or 8 ohms. 2 and 1 ohm amps draw more current from your battery so most likely they'll be Class D amps and require heavy gauge cabling. The Alpine MRD-500 is great at 2 ohms.
Old Oct 17, 2003 | 11:18 AM
DjPaj's Avatar
I will second the suggestion that you get the 801D for the Type R, that combo sounds damn nice together, although with your price range of 100-130 for an amp that needs to put out at least 300WRMS will be hard to come by...
Old Oct 17, 2003 | 01:28 PM
m3dia_lab's Avatar
jbl 600.1
us acoustics make very good amps and thier ratings are all at 12.9 volts whereas most amps are rated at 14.4
weak_tec
Audio / Security / Video
Jun 25, 2005 01:09 PM
CivHatchH22
Apr 12, 2004 09:21 AM
happyman12
Feb 18, 2004 04:01 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
b18tdelsol
Jan 7, 2003 08:25 PM
