amp installation kit Question
Old Oct 15, 2002 | 10:41 AM
MeKKa301's Avatar
Default amp installation kit Question
My setup will be the following..
First im getting a JL 500x1 for 2 JL 10w3's... And an Alpine 7894 headunit. Id like to install all that for starters. Then shortly after add a JL 75x4 and some JL components and coaxials for inside. Now my question is, for my setup which amp installation kit would you guys recommend. Ill be ordering my equipment from http://www.onlinecarstereo.com and they have amp kits for sale. I just have no clue as to which ones are of good quality and which would be the right fit for my setup. TIA.
Old Oct 15, 2002 | 01:37 PM
EndlEEsss's Avatar
Default Re: amp installation kit Question (MeKKa301)
8 gauge power / ground wire
and fosgate whitewolf rca
Old Oct 16, 2002 | 01:49 PM
incubus's Avatar
Default Re: amp installation kit Question (TweakMeUp)
white wolfs rock! They r becoming harder to find though.
I've never had a better RCA.
Old Oct 16, 2002 | 01:50 PM
incubus's Avatar
Default Re: amp installation kit Question (incubus)
Get a 4 gauge kit not a 8.
8 gauge will be good for about 500w rms (jl500.1 by its self)
to add another amp you will need to upgrade to 4 gauge.
Old Oct 16, 2002 | 07:37 PM
SpdNvy's Avatar
If you can afford it go with an 00 gauge to the distro block, say a four out block, then if you upgrade speakers and amp you would never need to change from the distro to the battery again. Go with the best that you can afford at the time to save expenses later. I would run 4 from the distro to the amps with a seperate fuse on each one coming out of the distro block. Just my .02
sirg-vtec
Audio / Security / Video
Jan 5, 2008 05:12 PM
EvenStar
10
Jan 25, 2007 07:55 AM
BIntegra99
Aug 11, 2005 05:37 AM
jwrcivicdx
May 1, 2003 10:57 PM
rodimus
Dec 17, 2002 05:27 PM
