Amp Installation DC2R
Im looking at putting a 4 channel amp under either the passenger Recaro, or drivers side. Probably leaning towards more the passenger side as it doesn't have the metal bit sticking out that the seat belt sensor connects too, therefore giving me .5" more clearance.
Anyone got any pictures of a similar install? And how well does it fit once someone is in the seat sliding back and forth etc. Anyone also had any overheating issues? Amp type recommendations (do they make slimline ones?.) I will just be running splits and a nothing too spectacular sub off it.
Thanks
Thanks
You can also add a little hight, [clearance] by using spacers to raise the back of the seat, giving you more choise in amps.
As mentioned, heat should not be an issue as amp is mounted properly, [flat] a space under amp will also help airflow.94
When doing the install in my Accord I installed the amps under the seats. Not sure how much room you have compared to mine, but I have plenty of clearance.
[/QUOTE]
Both my amps are A/B class so they can get a bit warm but there's ample room in my case for air to move across the sinks and even on the hottest of days they run fine. If they do happen to get too hot I can simply run air to them via the floor vents.
[/QUOTE]
adrian1281
Feb 19, 2004 05:29 PM
HatchBox
Audio / Security / Video
10
Sep 8, 2003 03:16 AM
