Alpine SPR-175A Dimensions?
i wish my scanner was working
The TOP is 2 3/8" Diameter (60MM)
From the tweeter grill to the Cup is 11/32" (9MM)
From the top of Cup to the bottom (excluding tweeter grill) is 5/8" (15.5MM)
BOTTOM Diameter is 1 15/16" (49MM)
if u need measurements for angle flush tweeter i have that also.
i bought these puppies new but the 6 1/2 subs dont fit in my '94 4-door teg
they have been lying here for 2 years. what a waste!
They don't fit?
I was thinking about a set for my ITR.
How do they not fit?
Could I also have the OD size of the flush angle?
Thank you for the measurements.
[Modified by Ukyo, 10:26 PM 9/6/2001]
2-doors are diff i think............mine dont fit cuz the magnet behind the sub is way too big.........i even went to get it customly fit in there.......he wasted one hour on it and said he couldnt do it.......even if he used a spacer u couldnt put the grill on it and it would look awkward. But i believe the 2 doors have enough space for them....try and see........otherwise return em and get Blaupunkt Overdrives. my alpine tweets were mounted in the mirror part of the door.......idiots forgot to glue the tweets to the holder and one day they came off and my bro closed the door.....they worked for a while and now they are trashed. I bought the Blaupunkt Tweets and i like them way better.......Infiinty would be superb though.
here are the dimensions for the angle cup:
looking at it from the top
- longer side is 2 5/8" (67MM)
- shorter side is 2 1/4" (58MM)
side view
- from the flat surface of cup to the angled tweeter position is 9/16" (14MM)
- back part of cup is 1" (25MM) at a 60 Degree angle
didnt u get a box for these? cuz its on there
i guess 'used' audio doesnt come in boxes
if u need more info feel free to ask.
side view
Thanks for the help.
I'm getting the speakers new but have not received them yet.
The woofers, do they have the 3-screw pattern pre-made into the basket of the speakers? Because from the pics on Alpine's site, all I see is the speaker with the cosmetic ring with 4-screw pattern on it.
these woofers have a 4 screw pattern on them.............u wont be using the cosmetic ring though unless u are mounting it in a custom location. the screw pattern will fit though.
shipsaeki
Audio / Security / Video
Feb 27, 2003 05:44 AM
LOwrestling2001
Jul 19, 2002 09:57 PM
