Alpine or Pioneer?!
Old Jun 28, 2004 | 05:39 PM
-DKap-'s Avatar
Default Alpine or Pioneer?!
aite i found a Alpine CDA - 9803 and a Pioneer DEH-P2500 they r both releativly cheap just a 5 dollar difference... the only difference they hav is ... 1 has a 1v preout that is the Pioneer and the Alpine has a 2v and in a personal opinion the pionner look better wat would u guys recommed?
Old Jun 28, 2004 | 07:07 PM
Goatsterrman's Avatar
Default Re: Alpine or Pioneer?! (-DKap-)
are you planning on running any amps???
Old Jun 28, 2004 | 07:22 PM
99FoxSi's Avatar
Alpine for sound. Don't go by looks cuz you'll be sorry. Alpine head units kick *** in general!
Old Jun 28, 2004 | 08:24 PM
-DKap-'s Avatar
Default Re: Alpine or Pioneer?! (99FoxSi)
most likely no amps for now gonna go for the bare min. for now and slowly build
i found some good poineer speakers that were discontinued that were goin for 70 bux wit 250 peak pwr and 100 rms so i think ima pick those and set those up wit the alpine still unsure
Old Jun 28, 2004 | 08:27 PM
john666's Avatar
get a alpine.
Old Jun 29, 2004 | 09:54 PM
-DKap-'s Avatar
Default Re: Alpine or Pioneer?! (john666)
aite well i got some more questions i think ima take the alpine but these r the specs i found
Plays audio CD/CD-R/CD-RW
12 FM/6 AM presets
Bass Engine
BBE processing
Source tone memory
MOSFET internal amp
Power handling: 23Wt RMS
Peak power handling: 50Wt x 4 channels
CD frequency response: 5-20,000Hz
CD signal-to-noise ratio:105dB
FM sensitivity: 9.3 dB
only 1 think i got questions about the CD frequency response wat should i look for and is that a good frequency response?! also the cd signal and same for the fm sensitivity good or no good and wat should i look for thx much apprechiated (ahead of time)
Old Jun 29, 2004 | 10:11 PM
kontai69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -DKap- &raquo;</TD></TR><TR><TD CLASS="quote">
about the CD frequency response wat should i look for and is that a good frequency response?</TD></TR></TABLE>
Considering a "normal" human's auditory system is only sensitive to frequencies between 20-20000Hz, I would say the Alpine's CD frequency response is more than adequate. The S/N is also around the standard. The FM sensitivity is a little on the low side. Most units are over 10 dB.
I've actually had the Alpine 9803 and found it to be a good sounding and well made headunit. I've also owned the more expensive Pioneer DEH-7400MP and found it to be less ergonomically sound (the buttons were too small). Also, the build quality of the Pioneer was inferior to the lesser costing Alpine. I'm currently using an Alpine 9811 which has more features (time delay, 4V preouts, etc).
Old Jun 30, 2004 | 08:14 AM
-DKap-'s Avatar
Default Re: Alpine or Pioneer?! (kontai69)
thanks that 1 helped tons ima check the alpine 9811 if i cant find that 1 for a decent price ima just spend the cash for the 9803 only 130 wit installation... not that bad
and do the preouts effect anythin...
and i dont really care much about the fm thing cuse i dont really like the radio
Old Jun 30, 2004 | 09:11 AM
spark plugs.
Guest
Posts: n/a
alpine 0wnz j00. once you get one, you'll never want anything else. i have NEVER heard anyone owning one and not being satisfied or changing to a different brand.
Old Jun 30, 2004 | 09:40 AM
-DKap-'s Avatar
Default Re: Alpine or Pioneer?! (spark plugs.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spark plugs. &raquo;</TD></TR><TR><TD CLASS="quote">alpine 0wnz j00. once you get one, you'll never want anything else. i have NEVER heard anyone owning one and not being satisfied or changing to a different brand.</TD></TR></TABLE>
very very very true... now the question is ... 9803 or 9811 wat do i got the money for...
and wait i dont understand y the hell did they make the 9823 and 9827 and **** those r suppose to be a newer model of the 9803 and 9811 .... yet they r just lower grade and blue bottons?(acutally 23s dont even hav blue bottons) but it says near the rms thing CEA compliant wat is that?
how much would a face plate from the 9827 cost?
Modified by -DKap- at 10:50 AM 6/30/2004
Old Jun 30, 2004 | 11:38 AM
nOOber's Avatar
get the best deck you can afford.
if you ever plan on getting amps down the road, then go for the alpine. ( for the higher pre out voltage)
If people picked decks based on looks, then every one would have those silver- disco -panasonics from a few years ago.
Old Jun 30, 2004 | 05:42 PM
toyzbus's Avatar
I have gone from Alpine (which my last 6 decks were) to Eclipse and I am definilty happy with the change. As far as the options for the topic, Alpine all the way.
Old Jun 30, 2004 | 07:36 PM
-DKap-'s Avatar
Default Re: Alpine or Pioneer?! (toyzbus)
well i am just curious were ur old alpines all in the same price range as the eslipise? cuse if they werent wouldnt really count (unless the alpines were more)
Old Jun 30, 2004 | 07:59 PM
toyzbus's Avatar
My current Eclipse sells for $600 and the Alpine before that was a $600 deck. For a brief time I had Kenwood of the same price range (but that wasn't even worth mentioning.)
Old Jun 30, 2004 | 08:02 PM
toyzbus's Avatar
BTW, replacement faceplates run for about $130 new. Also if it has the CEA rating on it, it is definitly a 2004 model.
Old Jul 1, 2004 | 06:20 AM
foz's Avatar
foz
Alpine
halfkoreanboy
Audio / Security / Video
May 4, 2009 10:59 AM
Scotty Dosent Know
Mar 14, 2009 09:19 AM
hondaZvic
10
Feb 13, 2007 12:17 PM
Jdmglenn
Oct 24, 2006 11:18 AM
Deerslayer
Sep 23, 2004 07:18 PM
