alarm on silent??
Old Feb 29, 2004 | 06:52 PM
blktyper919's Avatar
Default alarm on silent??
hi, i have recently took my car to the body shop for some body work. but the day i took it home, i noticed that my alarm is probalby set on silent (it locks and unlocks fine but no sound)because it was working fine before i took the car in. i am asking how i would set my alarm back to normal again?? i am not sure what alarm i have but its the stock one that came with my 01 integra.. thanks for your help..
Old Feb 29, 2004 | 06:57 PM
Ignitecivic's Avatar
Default Re: alarm on silent?? (blktyper919)
either check ur siren to see if they unplug it or if ur alarm got two button the I II just press the II couples times to set it unsilent.
Old Mar 2, 2004 | 01:33 AM
Default Re: alarm on silent?? (Ignitecivic)
hey, i tried doing those but im having troulbe can anyone give me some more advice?
Old Mar 2, 2004 | 05:47 AM
Goatsterrman's Avatar
Sounds like your alarm is in valet mode...depending on what kind of alarm you have and who installed it you can set it into Valet mode...
You said you think it was the stock one, What does the Remote look like?
Old Mar 2, 2004 | 06:50 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blktyper919 &raquo;</TD></TR><TR><TD CLASS="quote">hi, i have recently took my car to the body shop for some body work. but the day i took it home, i noticed that my alarm is probalby set on silent (it locks and unlocks fine but no sound)because it was working fine before i took the car in. i am asking how i would set my alarm back to normal again?? i am not sure what alarm i have but its the stock one that came with my 01 integra.. thanks for your help..</TD></TR></TABLE>
read the manuel, thats what its there for, i have a viper with 4 buttons, and on mine, u gota press the speaker button two times, then press unlock..
Old Mar 2, 2004 | 08:42 AM
Boxcar's Avatar
if water got in to your siren that would be bad news
Old Mar 2, 2004 | 06:27 PM
Default Re: (PearlEG94)
yeah my sis got a viper alarm too. she sometimes press the wrong button and the chirp on and off is silent but the alarm still armed and siren.
Old Mar 3, 2004 | 06:07 PM
Default Re: alarm on silent?? (Goatsterrman)
the remote says, KARR on the bottom and the armed button is in the middle..on the left says panic and the right says trunk....it came stock wtih my car from the dealer. i don't have a manuel either.. this sucks because when my alarm is going off... my car is blinking but no noise. ..
Old Mar 5, 2004 | 07:42 AM
It doesn't sounds like a factory alarm, it might have been installed from the dealership or commercialed out at the time of sale. I know you said it's locking and unlocking but is the car arming or disarming? Is the LED light flashing or solid, if it is solid the alarm is in valet, you need to finc the valet switch or button, usually installed on the kickpanel or somewhere under the steering column. Find that...put the key in and turn it to on...don't start the car, just turn the key to on, push the button or flip the switch, the solid LED should turn off, problem solved....if that is the problem.
Old Mar 5, 2004 | 04:10 PM
kaptr1d's Avatar
this is really similar to what is happenning to me. i have a viper 4 button alarm.
same ****, different alarm.
if its in valet mode, how do i switch it back? i know where the valet switch is but it doest seem to do anything.
Old Mar 6, 2004 | 10:26 AM
the car is locking and unlocking. when i set off the alarm, all it does is the lights just start flashing but there are no sirens.....thanks i will try what u said, i have tried lookin for a switch before but i couldn't find it.. but yeh i will try again.. !.
Old Mar 7, 2004 | 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaptr1d &raquo;</TD></TR><TR><TD CLASS="quote">this is really similar to what is happenning to me. i have a viper 4 button alarm.
if its in valet mode, how do i switch it back? i know where the valet switch is but it doest seem to do anything.</TD></TR></TABLE>
You said it's a 4 button viper remote, You should be able to get it out of Valet(if it is in valet) by pressing the "1" and "2" button...1*pause*2*pause*1*...about a half second pause inbetween buttons
iCollectStraws
Audio / Security / Video
Jul 7, 2009 12:28 AM
Coke in a Can
Sep 23, 2007 11:37 PM
gus738
Honda Civic (2006 - 2015)
15
Dec 19, 2006 09:26 PM
shipsaeki
May 6, 2003 01:23 PM
drsues02
May 17, 2002 10:06 PM
