Alarm issue after install
Old Feb 8, 2006 | 11:06 AM
ProjectDarkBlack's Avatar
Default Alarm issue after install
well I finished my alarm install (compustar basic with remote start), programmed the remote and everything looks fine. The problem is when the alarm is disarmed it beeps once every 30 or so seconds and after a few beeps the alarm goes off. It works fine when it is armed and I can use valet mode instead of just disarming it, but its not supposed to do this. Anyone have any ideas? TIA -kyle
Old Feb 8, 2006 | 07:09 PM
fcm's Avatar
fcm
Old Fart
Default Re: Alarm issue after install (ProjectDarkBlack)
It sounds like its going into rearm mode, like it is programed for passive arming and the chirps are warning you that it is going to arm, but why its going off I am not sure.
What model Compustar is it?
What car is it in? 94
Old Feb 8, 2006 | 08:27 PM
Default Re: Alarm issue after install (fcm)
Thats what I thought but I turned off passive arming and it didn't help. Its a 94 Integra RS and the model is R500A I think (that might be just the remote) . It isn't remote start actually, It works great except for that part. I don't think I messed the installation up, I think it is a programming issue. I did it in the middle of a dashboard swap so most of everything is impossible to reach ha ha
Old Feb 9, 2006 | 09:34 AM
suspendedHatch's Avatar
Sounds like the triggers are messed up or one of the wires aren't hooked up correctly (the alarm will act strange like that if so). Make sure you got the +/- on the parking lights, door triggers, and dome lights correct.
Old Feb 9, 2006 | 10:59 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">Thats what I thought but I turned off passive arming and it didn't help. Its a 94 Integra RS and the model is R500A I think (that might be just the remote) . It isn't remote start actually, It works great except for that part. I don't think I messed the installation up, I think it is a programming issue. I did it in the middle of a dashboard swap so most of everything is impossible to reach ha ha</TD></TR></TABLE> Need the model number, I do not recognize the R500A, look here for the remote.
http://www.compustar.com/support_C.htm
and here for the model number http://www.compustar.com/products.htm 94
Old Feb 9, 2006 | 11:08 PM
its the CM100-A
Old Feb 10, 2006 | 04:02 PM
fcm's Avatar
fcm
Old Fart
I have found a CM1000A that uses the R500 1way remote.......
http://www.staub.ca/tech/Manua...l.pdf is this it? It looks the same as the guide for the R500A remote, but is under CM1000A installation/user guide at ..... http://www.staub.ca/tech/manuals.html 94
JDM_Ej
Audio / Security / Video
20
May 4, 2014 06:27 PM
EJ8 GSR-T
13
May 1, 2007 06:58 PM
migizzel
Jan 27, 2006 03:37 PM
epraion62
28
Aug 25, 2005 09:58 AM
indy
17
Jul 12, 2001 08:25 PM
