alarm going off
Old Nov 25, 2007 | 07:46 PM
hks_Racing's Avatar
Default alarm going off
recently my alarm has been going off randomly everytime i would turn it on and leave it about 5-20min it would go off i had this alarm for a while and it never did this before its a prestige aps997 alarm
Old Nov 25, 2007 | 09:01 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: alarm going off (hks_Racing)
check your hood pin. what kind of alarm? check how many times the led flashes after the alarm is triggered
Old Nov 25, 2007 | 09:10 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: alarm going off (NHswaps13203)
What kind of car ? and what kind of sensors are added? Also check the led-if there is one and see what zone is getting the trigger. Also a weak car battery could give you this problem. This is one reason that you should have a dei 520t back up battery.
Old Nov 25, 2007 | 09:22 PM
Default Re: alarm going off (wrx-killer-Sti-eater)
pretty sure its not the battery. i would bet its the hood pin isnt touching rite. seen it a million times. specially on civics if they are on the firewall there is little surface for contact. just gotta wait and see.
Old Nov 25, 2007 | 09:23 PM
oh i just realized its a prestige. its probably a bad shock sensor. those things are weak
Old Nov 25, 2007 | 09:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHswaps13203 &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure its not the battery. i would bet its the hood pin isnt touching rite. seen it a million times. specially on civics if they are on the firewall there is little surface for contact. just gotta wait and see.</TD></TR></TABLE>
most likely if it was a bad hood pin or dooor pin if he armed the car it would tell him a trigger was open by a responce chirp back from the alarm. A voltage drop real quick will give him the problems that he is having now. I seen this over and over and over again. This leaves most installers stumped and wonder wtf is going on. A bad ground, or trigger like you said or a faulty brain can all be the caused. Do a run down. Unplug each sencer that you have one by one till you weed it out.
Old Nov 25, 2007 | 09:35 PM
in most cases this is true for the hood pin but like i said i seen it a million times. now the shock sensor is a know problem. and if they connected the starter kill to constant 12v then thats whats killing the battery. has to be conected to ign 1
SPEED123
Audio / Security / Video
Jun 26, 2011 12:20 AM
JBB93Coupe
14
Jun 16, 2009 02:11 PM
pdd
Honda Civic (2001 - 2005)
Jul 28, 2007 09:50 AM
JDM-EJ1
Aug 7, 2006 01:41 AM
dukers
Jul 18, 2005 05:39 PM
