99 Accord head unit problems
Old Feb 20, 2008 | 02:44 PM
romes591's Avatar
Default 99 Accord head unit problems
I tried to install my alpine head unit and everything would light up but no sound would come out of my speakers. I looked in the manual and found that the IC power should be switched to off, so I did that but nothing happened. Did my internal amp die? All I did was take the unit out of my old truck and put it in the accord so i dunno how it could have died.
As a side question... which fuse in the fuse box is for the radio?
Thanks for any help.
Old Feb 20, 2008 | 04:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: 99 Accord head unit problems (romes591)
Turn the IC power back on. 94
Old Feb 20, 2008 | 05:33 PM
romes591's Avatar
yeah it hasnt worked with it on or off, but i will try again.
anyone know the fuse number for the radio?
Old Feb 21, 2008 | 06:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: (romes591)
Is it not turning on at all, or is it turning on but no sound?
Are you using the HU to power the speakers or are you using off-board amp(s)?
If the HU turns on and there just is no sound, the fuses are good, Alpine HUs will not turn on if either the acc. or constant power fuses are blown. 94
Old Feb 21, 2008 | 08:07 AM
romes591's Avatar
Default Re: (fcm)
I'm using the HU to power the speakers. The display and everything turns on, just no sound. I made sure the power IC was set to on as well and still no sound.
Old Feb 21, 2008 | 12:44 PM
dj-t's Avatar
it can be that somewhere in you car you have a grounded out speaker wire, test each line and see if it is grounding out
Old Feb 21, 2008 | 04:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: (dj-t)
Are you using a harness adapter, or is the Alpine hardwired, to the OEM radio harness? 94
Old Feb 21, 2008 | 06:10 PM
romes591's Avatar
Default Re: (fcm)
hard wired to oem harness.
Old Feb 22, 2008 | 12:55 PM
romes591's Avatar
which fuse is for the radio? none of the fuses under the hood or in the driver side pannel are labeled for it?????? my Hu wont even turn on.
Andy Larkins
Audio / Security / Video
Oct 5, 2015 09:18 AM
toicy4ya
Jan 8, 2012 05:23 AM
mugbeme
Sep 3, 2006 03:25 PM
azz_kicker
Aug 19, 2006 10:34 PM
ppfalcon
Sep 7, 2005 08:25 AM
