96 civic cd player installation help
Old Aug 31, 2006 | 01:30 PM
Takymoto's Avatar
I'm a Jackass
Default 96 civic cd player installation help
my friend got the harness where it keeps his stock radio in his car.. (cause he has the keyless entry.) and then the harness connects into alpine cd player.. now we turned on the car and the cd player didnt turn on. but right now his turn signals dont work either.. Does everything need to be hooked back up again before the cd player will. work? He put the cd player in the din above the cup holder. thanks
Old Aug 31, 2006 | 01:51 PM
B18C_EJ8's Avatar
Did you check for blown fuses?
Old Aug 31, 2006 | 01:53 PM
Takymoto's Avatar
I'm a Jackass
Default Re: (B18C_EJ8)
nope but will do any other suggestions or problems that you faced
Old Aug 31, 2006 | 02:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: (wOrd!)
Does the key-less still work?
Check both fuse 47 -7.5A, [hot at all times] in the under hood fuse box and fuse 28 - 10A, [hot in acc. and/or run] in under dash fuse box.
Do the hazard lights work?
signal light fuse is fuse12 - 7.5A, [hot in run and/or start] in under dash fuse box.
BTW you may have to run a fused lead from the batt. for the HUs constant power, [yellow] instead of using the oem radio harness one.
what is the make and model of the HU? 94
Old Aug 31, 2006 | 05:56 PM
Takymoto's Avatar
I'm a Jackass
Default Re: (fcm)
hey thanks man it was the fuse under the hood.. everything works perfectly now!! thanks again..
immrtaltchnq
Audio / Security / Video
Jul 18, 2009 10:01 PM
tyler100
Jan 5, 2008 02:39 PM
GraphiteMW
Jul 14, 2007 07:32 AM
NiCkArInO
Aug 21, 2003 04:41 PM
