6x9's in integra
I've fit 6x9's back there in my '94. You've gotta remove your rear seats and all the side panels. And then remove the oem speaker and bracket assembly. The 6x9's have to go in at a angle and you've gotta make some brackets out of like back strap material or something. Test fit everything and then reinstall the panels and seats.
You can also carefully cut out the rear deck panel with like a Dremel tool and top mount the 6x9's and the grills right into the indent.
The 6x9's are cool if you're not going the subwoofer route. At least you'll get some sort of bass. If you do have subs, this is pretty much a waste of time. There's plenty of 6.5" that sound great.
why not just get both....ive got component 6.'s fronts, 6.5 on rear sides, and 6x9's on my rear deck w/ 3 10's in the turnk...car is slo as hell....if you put the speakers in the rear deck though youll have to make an enclosure or else the sub pressure will destroy the cones....
PowerLeg
Jul 6, 2010 05:35 PM
99IntegraGS
Audio / Security / Video
Jun 22, 2005 09:28 PM
