5 channel amp?
Old Apr 12, 2009 | 08:15 PM
GetawayInMoscow's Avatar
Default 5 channel amp?
Okay so I have 4-ohm speakers in the front and rear, but a 2-ohm polk sub. I need to get these suckers amped, or at least the front components and sub.
Would a 5 channel amp fit the bill? Would I be able to run the speakers at 4 ohm and the sub at 2 ohm or does everything on the amp have to be either 2 or 4?
Old Apr 12, 2009 | 09:47 PM
mrdeadman's Avatar
They let me pick
Default Re: 5 channel amp?
I have the Hifonics zeus 8thousandsomething. It has 5 channels, 1X300 into 2ohms and 4X55w 4ohms or 4X110watts 2ohms RMS. I really like it, it is a great amp. I'm running my speakers and sub off it now.
EDIT: The reason I have the five channel is because my hu won't out put anything through the speaker wires. So either I run just the fronts and no backs or amp them all.
Old Apr 13, 2009 | 02:48 AM
tazeat's Avatar
While they do make good 5 channel amps, I would highly recommend just doing a 4 ch. and a separate class-d 1 ch. amp. It comes out quite a bit cheaper (generally) and you generally get more power on all the channels when they are split up especially when you look at the power/$$$. I'm not saying good 5 channels don't exist, they do, but typically you will pay more to have it in one unit.
You can however run different channels on a 5 channel with a different load (ohms).
edit: and to the above, either
A) get a head unit w/ 3 outputs (F R & Sub) so you can control everything on the head unit (I don't know how you can live w/o this :p).
B) use the line out on the main amp and run it to the sub amp (assuming the amp has them)
Old Apr 13, 2009 | 04:48 AM
Jturtle's Avatar
New User
ya you can do that and on some you can even run them @1ohm for the substage. I would look on ebay and see if you can find any Memphis Belle's. Great amps for the money and put out plenty of power.
Old Apr 13, 2009 | 09:54 AM
Is there an amp out there that can run 4 ohms to the front speakers and then 2 ohm stable to the sub?
Edit: Would this work? http://www.crutchfield.com/p_113X600...0F.html?tp=115
Old Apr 13, 2009 | 10:06 AM
mrdeadman's Avatar
They let me pick
Do you mean bridge 2 of the channels for the sub and use the other 2 for the two front speakers? I'm pretty sure it will work. Lets let someone else confirm though.
Old Apr 13, 2009 | 10:08 AM
98civdx's Avatar
Master Detailer
your better off getiing a four channle for the speaker and a mono for the sub,
your going to have better results that way.
Old Apr 13, 2009 | 10:20 AM
Okay so if I did that would I run a 4 gauge wire into a distribution block and then an 8 gauge to each amp?
How do I run two remote turn on wires from the head unit? Do I just run 1 and then splice the other?
Old Apr 13, 2009 | 10:35 AM
tazeat's Avatar
4 then 8 would work, I've done it. But if your pulling a lot of power, I might even go thicker. But that would work fine.
As far as the turn on, ya you can just daisy chain them (run one to the first which has two wires, the second going to the second amp).
Old Apr 13, 2009 | 02:41 PM
98civdx's Avatar
Master Detailer
yes,
just as he said i have that done in my civic now,
i have a 1000 watt 2 channle and 400 watt 4 channle
im runing a 4 guage from batt into block 4 guage into the 2 channle and 8 into the 4channle ,
do the remote just as he said.
remember if you power it with a 4 guage ground it with 4 guage.
King_j
Audio / Security / Video
Aug 17, 2003 05:05 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
schwinn
Jun 19, 2002 10:54 PM
juniordc2
12
Jun 4, 2002 11:07 PM
GoLowDrew
Jul 17, 2001 09:49 PM
