1st time installing a alarm?
Old Jul 23, 2004 | 11:04 AM
DC2 to AP2's Avatar
Default 1st time installing a alarm?
how hard wuould it be to install a alarm in my car with it completely gutted. i wanna try and install after i get my paint job done and before i put everything back in.
when i say gutted i mean gutted.
Old Jul 23, 2004 | 11:25 AM
Odessa's Avatar
Default Re: 1st time installing a alarm? (xdriver)
Wow You must have lots of free time
Old Jul 23, 2004 | 11:29 AM
spark plugs.
Guest
Posts: n/a
Default Re: 1st time installing a alarm? (Odessa)
what alarm is this? read the directions and see what wires you can run.
Old Jul 23, 2004 | 11:43 AM
DC2 to AP2's Avatar
Default Re: 1st time installing a alarm? (spark plugs.)
amazingly i have alot of free time! have a gf and a full time job.
im looking at getting the compustar. whats a good online place to get it? should it be difficlult to install?
Old Jul 23, 2004 | 12:07 PM
Odessa's Avatar
Look on ebay After researching, I found that I probably need only about 15 wires to connect the alarm (not including 3 sensors and a bypass).
Old Jul 23, 2004 | 08:44 PM
fcm's Avatar
fcm
Old Fart
Hard as hell, as I don't see a oem wire harness, now is a good time ,[or as you reinstall oem harness] to run wiring for stereo or wires that may be needed for alarm options, 95% or more of the alarm wiring is done on the drivers side under dash, even trunk/hatch [ use trunk/hatch ajar ] one 12ga wire will be needed from driver underdash to trunk/hatch latch if you are doing power T/H pop, if you are doing some kind of window mod,[ dei 530t] you will need to run some wires into drivers door, and you will need to run 3 wires into engine bay.
hope this helps, but I think there are other things you need to do before you start on the alarm lol . 94
maal15
Nov 11, 2008 08:46 AM
lamboextreme
Audio / Security / Video
Sep 22, 2007 10:07 AM
WildChild
Dec 5, 2005 12:45 PM
White S2k
18
Nov 1, 2002 05:18 PM
DRxCIVIC
Jul 3, 2002 06:45 AM
