04 accord head unit replacement
You want to replace the headunit?? Why? You know how much a pain in the *** that will be? The piece is all one unit, digital climate controls, navigation if applicable...the piece alone from honda will cost you probably a good 5,000. As for a kit, metra or ami does not make anything for it, simply because of the price for the climate controls around the radio. If you miss the subs and amps, get a low level input and tap audio from the back speaker wires. Run 12v accessory wire to remote turn on, power wire, ground, and you have your subs again.
Guest
Posts: n/a
yeah, why would you replace a nice-*** head unit? http://www.digitalfotoclub.com...91327 that's the metra kit, but use signal converters and amps and retain the stock deck.
There is a kit that replaces the headunit but unfortunately it does not work with the 6 disc changer. Metra's kit replaces the lower storage pocket. Honda also has a factory piece to replace the lower pocket.
http://www.autotoys.com/x/cata....html
bilal3
Apr 6, 2007 04:23 AM
