Trent89's CRX Si B20 Y49
This is my 1989 CRX Si. Its been a long process but its starting to come together.
Engine 99-00 jdm b20b from hmotorsonline DA driver side engine post DA rear T bracket Gates timing belt Gates alternator belt Oem Honda water pump Oem Honda koyo tensioner Oem Honda tensioner spring Oem Honda spark plugs Oem Honda intake manifold gasket Obd1 integra ls intake complete manifold Oem Honda throttle body gasket Oem Honda iacv gasket Oem Honda speedometer cable Oem DA integra throttle cable Oem Honda clutch cable Innovative b series cable mounts Tanabe racing medallion exhaust obd0-obd1 ecu jumper denso radiator w/ gates radiator hoses Transmission B16 cable w/ lsd 4.26fd rebuilt by whoopee doo racing Lightweight fidanza flywheel Oem exedy clutch Oem Honda clutch bolts Oem Honda flywheel bolts Innovative shift linkage Energy suspension shifter bushings DA integra intermediate shaft DA integra axles brand new from o’reillys Suspension & Brakes Koni Yellow struts and Ground Control coilovers 450lbs. front /500 lbs. rear Suspension Techniques Rear Sway Bar HF Front Sway Bar Re-drilled '94 Legend Front Rotors ITR Honda Front Brake Pads DA Integra Front Knuckles Accord Wagon Front Calipers DC GSR Rear Disc w/ Honda Pads DC GSR Master Cylinder and Brake Booster 4040 Prop Valve Earl's Stainless Brake Lines all around ARP Extended Wheel Studs Blox Black Lug Nuts the day i brought it home. https://i515.photobucket.com/albums/...123_131705.jpg First thing i did when i got the car was repaint the engine bay. http://i515.photobucket.com/albums/t...019_180332.jpg http://i515.photobucket.com/albums/t...021_213903.jpg with the help of my friend WhiteSlips, we got the motor dropped in yesterday. http://i515.photobucket.com/albums/t...pscf3b3053.jpg |
Re: Trent89's CRX Si B20 Y49
I did the engine bay the same way by just taping things up instead of taking everything out. Looks good man
Looking good!
what are your plans for this crx?
Originally Posted by slowDB7
(Post 48862926)
wired up the knock sensor and o2 sensor tonight.
it took me 6 different alternator belts but i finally cleared the frame rail. theres probably a few millimeters between the alternator pulley and the frame rail. i have about 1/4" on the tensioner that i could pull the alternator closer to the engine. http://i515.photobucket.com/albums/t...psaa60bd63.jpg grinded off the rust and painted my headlights flat black http://i515.photobucket.com/albums/t...ps99e38360.jpg |
Headlights look great, I might do that!
It looks real good so far!
What color is that yellow? Looks similar to the E36 M3, Dakar Yellow!
Originally Posted by GunsBehindBars
(Post 48876965)
the engine bay looks brighter cause its new paint and the exterior is kinda faded
Originally Posted by r_Senik
(Post 48878951)
Barbados yellow, the original color for this crx.
Updates or we riot.
i havent got to work on my car in a few days. i had to hang all new drywall in my garage ceiling and i am in the middle of a move to ft worth, tx. we sent our 3rd 16x8.5' trailer load down this morning. i should get the chance to work on it for the next few days though and i hope i can get it running this weekend
things i have left to install before i can get it running: new exhaust starter intake front bumper throttle cable clutch cable ecu radiator axles shift linkage and shifter |
about to install the exhaust
http://i515.photobucket.com/albums/t...psb8be1521.jpg http://i515.photobucket.com/albums/t...psb4223039.jpg |
Looking good
tried to start the car up yesterday and it wasnt getting fuel to the engine. i never hear my fuel pump prime when i turn the key either.
Check your grounds, especially near the thermostat. Also check the main relay. ECU throwing any codes?
If this goes anything WhiteSlips swap went, it'll be super clean.
(Post 48922162)
car is running and driveable. it idles really low and surges and will eventually die if i dont feather the gas. i was able to drive it on the trailer though. just moved to ft worth yesterday. hoping i can get it running right so i can start cruising it.
http://i515.photobucket.com/albums/t...ps3647407a.jpg http://i515.photobucket.com/albums/t...psdd66b9a5.jpg http://i515.photobucket.com/albums/t...psf6b5acaa.jpg |
Dam I wanna get mine out
great car man!
Looks great man.hope you get it ready to go. Can you post any pictures of the body and interior?
Nice crx man well come to Texas also
