My turn for a build thread...just something small
Old Mar 21, 2008 | 07:06 PM
primetimeracing's Avatar
Default My turn for a build thread...just something small
I blew my head gasket in my 90 crx si...so i decided to put a y8 head on it..i picked up the head from my buddy for 60 bux..he doesnt know much about cars so he didnt know how much it should cost . It came with the IM, TB, fuel rail, injectors, aem cam gear, and he said something about a cam..im not sure about that though. Here is my Crx before i started working on it.
The new parts.
The way that headgasket looks they think im driving a v6 lol..i have to return it
In the process of working on it tonight..the first night of work...This is the first time ive done a head swap...it doesnt sound like its ganna be that hard but i just dont want to [freak] anything up ..i should be getting a lot more parts in within the next week or so.
Thats it for tonight..more in the morning
Chris
Old Mar 22, 2008 | 04:55 AM
Default Re: My turn for a build thread...just something small (primetimeracing)
i do have some questions though..like which intake manifold should i use?? the 1 off my a6 or the one of the y8 cuz i think mine is in better shape but i dk if they will bolt right up..
Chris
Old Mar 22, 2008 | 05:10 AM
superex87's Avatar
They are somewhat interchangable.
First check to see if the y8 IM has the manual trans idle valve or the auto one (manual one will be on back of IM, auto on will be on bottom of throttle body.
If its the manual one then your good to go for the most part, you have to use you stock si injectors if you use the y8 IM, the y8 ones work differently.
do a search for the y8 swap theres some good write ups on it.
Old Mar 22, 2008 | 07:02 AM
Default Re: My turn for a build thread...just something small (superex87)
alright...well i couldnt find but 1 write up on the y8 swap..and it didnt rly go into detail
Old Mar 22, 2008 | 07:44 AM
biggee's Avatar
It will be easier to use your A6 manifold, but the Y8 manifold is better. Also unless you bought a conversion harness and you have the distributor, ECU, etc to convert it to OBD1 then it will be much easier to stay OBD0. annnnd, if you are staying OBD0 how are you planning on running Vtec?
Old Mar 22, 2008 | 01:40 PM
Default Re: (biggee)
well i wasnt sure about that...i was thinking i could just use an apexi s-afc 2 or something
Chris
Old Mar 23, 2008 | 05:09 PM
Default Re: (primetimeracing)
so got some progress...took my new head apart and sent it off to get cleaned up and decked...now im stuck on a road bump and cant get my crank pully bolt off...ive broke 2 sockets 3 extenders and a wench trying to get this bolt off...and i cant figure out how to get it off..
i do have some questions about timing belts and tensioners, and water pumps...with my d16a6 block..i can run my stock tensioner, stock water pump, and a d16y8 timing belt??? i saw somebody talking about having to use a d15b7(not sure if thats right) timing belt maybe?
should i use this y8 intake with my Si injectors or use my a6 intake mani???
Old Mar 23, 2008 | 06:00 PM
crxricer66's Avatar
crank pulley, use an impact gun. as for manifolds, use the y8 if possible cuz its got better flow.
Old Mar 23, 2008 | 06:05 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (crxricer66)
Dear god, shrink your pics, you lagged my FIOS....
Old Mar 23, 2008 | 06:16 PM
Default Re: (***$nyper)
i used an impact and that didnt work..it just started to try to do its hammer thing..didnt want to turn..but i dk if i should be able to grab the socket on the impact with my had and pull the trigger and it not turn...i dk..i used an air ratchet also and that didnt work either...
and asssnyper..i resized my pics on the second set...what is fios?
Chris
Old Mar 23, 2008 | 07:16 PM
Rease3's Avatar
fios is the fastest internet out right now. and use a breaker car and a big flat head to hold the flywheel. and it will come off with ease thats how i did mine.
Old Mar 23, 2008 | 10:34 PM
tunerkid7's Avatar
Default Re: (Rease3)
im not feelin the part about you rippin your friend off thats not to cool
Old Mar 23, 2008 | 11:06 PM
1989CivicSi's Avatar
Default Re: (tunerkid7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 &raquo;</TD></TR><TR><TD CLASS="quote">im not feelin the part about you rippin your friend off thats not to cool</TD></TR></TABLE>
x2, but good luck on the build.
Old Mar 24, 2008 | 03:08 AM
Default Re: (1989CivicSi)
well when he got it for free he doesnt care so w/e...but how do i get to the flywheel with the engine in the car??
Chris
Old Mar 24, 2008 | 09:24 PM
Old Mar 25, 2008 | 04:01 AM
I CRX I's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primetimeracing &raquo;</TD></TR><TR><TD CLASS="quote">well when he got it for free he doesnt care so w/e...but how do i get to the flywheel with the engine in the car??
Chris</TD></TR></TABLE>Magic my friend! puure MMagic! . seriously? tranny must come off<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 &raquo;</TD></TR><TR><TD CLASS="quote">im not feelin the part about you rippin your friend off thats not to cool</TD></TR></TABLE> he didnt rip his friend off, even if he didnt get it for free, he had no use for it (assuming from his technical backround) so it would have probably gone to waist anyway. now he has $60 in his pocket thats what friend are foooorr
Old Mar 25, 2008 | 12:59 PM
Default Re: (I CRX I)
exactly...but i do have to take the tranny off before i take this bolt off??
Chris
Old Mar 25, 2008 | 03:11 PM
welfarepc's Avatar
look in the FAQ for help getting off the crank pulley if u dont want to use an impact
I would use an impact gun, its the easy way. it it wont just, GO... try this
put a socket on it, with an extension (1/2 inch of course)
give a couple good bash's to the end of the extension with a decent hammer. you are trying to loosen up the threads.
after that, switch over to your impact, make sure your compressor is fully charged, and do short bursts of impact gun. dont just hold it.
it will go. some tapping fluid might help
i just had a weird idea? freeze the bolt with a can of compressed computer air upside down, it would snrink the bolt a bit then zip it off with the impact? haha who knows but good luck (either way the above method is tried and true)
Old Mar 25, 2008 | 03:43 PM
harmonator84's Avatar
Default Re: (welfarepc)
Looks like a good start..
Old Mar 25, 2008 | 04:00 PM
0c00l's Avatar
I just went thru this with my B18A1, I actually put the block under my EF front end and lowered the car onto the block and wedged a block of wood where the crank spins near the wall of the block and then used a breaker bar. I coudl't freakin believe how hard it was but it came off!
Old Mar 26, 2008 | 06:23 PM
Default Re: (0c00l)
yea its driving me crazying..i tryed the impact gun in short bursts...still didnt work..im ganna try lowing the car onto a brick with a wrench attactched to the bolt and so if that works...i dk what going on..anyways
Update...the new y8 is at the machine shop getting all seals and valves replaced...it is also being decked .020. thats ganna cause my compression to be where..in the mid 11's i think..so deff not a good motor for boost like i would love..but i guess i could do a all motor build with it...and i still dont know how im ganna wire up vtec...i picked up my new vtec controller but dont have a wiring diagram...does anybody know how to wire one of these up...?
Old Mar 27, 2008 | 10:30 AM
Old Mar 27, 2008 | 11:09 AM
grand champ's Avatar
That thing that looks like a computer mouse, just cut it off with wire cutters and then run the wires to your vtec solinoid and the other ones to ground.
Old Mar 27, 2008 | 08:17 PM
Default Re: (grand champ)
alright...nothing to the ecu?? lol..yea but i still dont know what yall are talking about on the throttle body that is there if its an auto and not if its a manual
Chris
Old Apr 7, 2008 | 08:52 AM
Update...going for a huge change in plans here....so ive decided to say [freak] this mini-me swap..im just ganna do the full z6 swap...so i got a block from a z6 that has a micro polished crankshaft. i wanted to go ahead and get some eagle rods and vitara pistons so i can get ready for boost but i didnt think it would run very well at all with that low of compression..so im sticking with stock internals..
I have my y8 head in the shop. its being milled .02 down to make sure its flat...reseated all the valves and new seals and springs...i bought a zex v-tec street cam...it will be pretty nice...i have a stage 2 exedy clutch and an eight pound flywheel...the car is going to be pretty quick...then the Td04 is soon to come..will have pictures of progress soon
Chris
