My Del Sol Si
Old Jan 23, 2011 | 09:30 AM
TheJakePatty's Avatar
Default My Del Sol Si
Hey guys! I have a 1995 Del Sol Si w/ a D16z6 SOHC vtec. I'm going to drop a B16a jdm with a GSR 5 speed trans, and run all natural no force induct. They are in order mostly of the project so far. My del sol was a grad present. I had to redo the intake and muffler.
Right after I got it
After i had it for a a couple months
Old Jan 23, 2011 | 09:35 AM
Default Re: My Del Sol Si
Continue
Sanded
Wet paint after 2 1/2 months of waiting...
Picking up from the paint shop
Old Jan 23, 2011 | 09:39 AM
continued
garage kept it's spoiled
Head b16a gen 1
Name:  25 B16A JDM SIR OBD0 Gen 1.jpg
Block b16a gen 2, i cleaned it for 2 hrs
Name:  26 Clean Block.jpg
Name:  27 Clean Block 2.jpg
Name:  28 Clean block 3.jpg
Name:  29 B16A JDM SIR II OBD1 1999-2000 Civic SIR II.jpg
Crankshaft
Name:  30 Crank shaft.jpg
Old Jan 23, 2011 | 09:44 AM
continued
Ctr high compression pistons 11:5:1
Name:  31 CTR piston compression 11.5.1.jpg
Driving off
finally put together after being rebuilt
I washed it three times that day
Old Jan 23, 2011 | 09:46 AM
Name:  42 Del Sol Cluster.jpg
The skunk 2 intake manifold with Omni 68mm throttle body
Name:  43 B16a skunk2.jpg
Name:  44 b16a head.jpg
Old Jan 23, 2011 | 09:49 AM
Heres a video of a drive by off my youtube channel.
http://www.youtube.com/watch?v=vlL6LK8ByMY
Old Jan 23, 2011 | 02:20 PM
CF_EM1's Avatar
Looks pretty good just needs slammed and the hood needs to go but to each his own
Old Jan 23, 2011 | 04:17 PM
r_Senik's Avatar
for you. lower it and it'll look better...
Old Jan 23, 2011 | 04:20 PM
markspan6243's Avatar
Flattery Will Get You Everywhere
loose the scoop, lower it, stock tails, then itll looks good. otherwise,
Old Jan 23, 2011 | 05:40 PM
donmeca2020's Avatar
that hood scoop definetly doesnt fit the car.. and the tails are ehhhhh but if you like thats all that matters
Old Jan 24, 2011 | 01:00 AM
Rude Awakening's Avatar
Daughter not possible
Props for not doing the same thing as everyone else.
But, of course +1 on the sentiments about the scoop.
Old Jan 24, 2011 | 06:17 AM
Yea i'm starting to not like it. I has going to duct it to a heat box for my intake, cause cold air around here isnt the best idea due to puddles, and sitting water. I think i'm either going to get another black hood or a oem carbon fiber one. Then the tail lights i'm smoking them. And after i drop the B16 in it i will be doing major suspension work on it. I plan on dropping down an 1in or so not to much, not a huge fan of belly scrapers ya know? haha
Z6sol
Aug 19, 2017 09:08 PM
EFKIOS597
Nov 1, 2009 03:52 PM
Mjh787
May 9, 2006 07:51 PM
b18c5-EM1
Jan 30, 2005 07:06 AM
DelSol Dude21
Aug 11, 2001 06:17 PM
