Monjarassi: The Final Push, Quest for that Big Powa
Old Oct 9, 2013 | 06:36 PM
monjarassi's Avatar
Default Monjarassi: The Final Push, Quest for that Big Powa
Car: 2004 Honda Civic Si
Tuner: Brain @ Speedlab.net
Power Goal: 600hp
Fuel: e85
Drivetrain: 5spd ep3 tranny, LSD, CompCLutch SS
Turbo: PTE 6266 .82 ar
Target boost: 20+psi
Managenment: Hondata Kpro
Lubricants: BradPenn / AMS oil
Aftermarket Goods:
K-TUNED-AFH-KARCEPTS-GOLDENEAGLE-ARP-ID
PRECISION TURBO-FABWORX-HPT-JE
EAGLE-ACL-AEM-HONDATA-COMPETITIONCLUTCH-TIAL-BREMBO-VIBRANT-RUSSELL
INNOVATIVE MOUNTS-WALBRO-AEROMOTIVE-DOWNSTARINC
The narrative that no one cares about:
This build will be started due to the failure of a rod bearing, motor was still salvageable, wish I could say the same for the crank.
Will not be doing a crazy build or nun like that, simple and clean, no need to blow 10k.
So with that being said subscribe, check back frequently and feel free to give input, and/or criticism. Sit back and enjoy my work.
Old Oct 10, 2013 | 08:58 AM
nahonda04's Avatar
Surje.motorsports
Default Re: Monjarassi: The Final Push, Quest for that Big Powa
let me get that front bumper :D..
nice build man, youve been following mine on clubep3 under my other s/n dc5-rs!!
Old Oct 10, 2013 | 02:55 PM
monjarassi's Avatar
thanks man, yea i seen that one
Old Oct 10, 2013 | 08:34 PM
monjarassi's Avatar
Soon after the teardown I made my decision to go through with the build, brainstormed with my tuner on what setup would suit my goal in power level and started searching for the parts I needed. Came across a deal I couldnt refuse!!
JE 86.5mm pistons 10:5:1 compression ratio
JE wristpins
Eagle H-beam rods ARP rodbolts
ACL STD thrust washers
Old Oct 11, 2013 | 01:06 PM
nahonda04's Avatar
Surje.motorsports
you may have to hone the "bushings" on the eagle connecting rods to fit the JE wrist pin in. I had to do this on my build because for whatever reason eagle keeps them at stock wrist pin bore so you can re-use your stock wrist pins....dumbest thing ever imo, but my machine shop did it for $20
Old Oct 11, 2013 | 03:20 PM
monjarassi's Avatar
well these pistons are custom and the wrist pins are made to spec with these rods.
Old Oct 12, 2013 | 10:54 PM
monjarassi's Avatar
Not too long ago a pretty important package made its way to my hands, after being lost for 48 hours at the local UPS facility after a 5 day journey from its origin.
More power calls for heavier duty clutch system.
Nice upgrade from my previous CompClutch stage 4 system :giggity:
Old Oct 15, 2013 | 06:21 PM
monjarassi's Avatar
Shortly after I got in contact with Ryan from AFH and he had in stock 2 GE turbo manifolds, no need for the 3-4 month wait from manufacturer. What a great opportunity to upgrade the old RBC and upgrade, not to mention he gave me a killer deal on it.
Great customer service I received from AutoFair Honda and he will now be supplying me with a bunch of parts ima need for the build, highly recommend him for any needs no matter how small nor big the order might be, he got it!!
Went ahead and threw on my fuel rail and Aeromotive A1000 fuel pressure regulator, getting ready for that fuel system. Will need new injectors and throttle body soon.
Old Oct 19, 2013 | 03:56 PM
monjarassi's Avatar
A lil peep glimpse of what im working with this weekend!!
Because RaeKar?
Adios to all the unnecessary stuff!!!
Old Oct 27, 2013 | 06:14 PM
fugazzyef's Avatar
Viejo!!!! awesome project!!!!!!!!!!
Old Oct 27, 2013 | 07:54 PM
monjarassi's Avatar
Old Oct 30, 2013 | 05:27 PM
monjarassi's Avatar
Just received an important package from AutoFair Honda:
Rod bearings
Main bearings
Crank seal
70mm P2R tb gasket.
Huge thanks to Ryan for the parts. More to come.
Old Nov 11, 2013 | 06:59 PM
monjarassi's Avatar
For all my followers, take a look at our eshop and just simply scroll through, see anything u like, want , or need for your build or project?
Enter "SPOOLBUS" as the promo code at checkout and receive $10 off on all orders over $100!!
http://boostedk20.com/eshop/
Old Nov 15, 2013 | 01:38 AM
monjarassi's Avatar
So finally the FMIC came through. First off gotta say thanks to 'echo3gulf' for the hook up, and great packaging skills!
The fitment is great and nothing else i could ask for, ill let the pics do the talking.
And a sneak peak of what i been doing to the engine bay.
Old Nov 22, 2013 | 08:38 PM
monjarassi's Avatar
Got the call i been waiting for, machine shop was done and ready to give back my stuff.
The shop met my expectations and had a fast turn around, would've been faster if the crank situation hadn't happened.
For any locals in need of machine work, no matter how big or small the job might be, i highly recommend them to you.
Westside Performance & Machine
9100 Emnora Ln, Houston, TX 77080
(713) 465-7996
I had them do the following:
Bore the crank .5 over
Hot tank it
Polish & balance crankshaft (with Flywheel & PP)
Resurface flywheel
Now onto the pix!!
GE oil squirter block off plugs installed
Old Nov 29, 2013 | 06:56 PM
monjarassi's Avatar
Last minute Black Friday shopping got me this!!
Gotta hate this daytime saving bs and having not enough lighting to do work in the garage. The answer to my swearing has arrived, thanks to the wifey who got me this.
-120 bright white LED lamps
-Detachable magnetic stretch cord ends for flexible attachment options
-Recessed fold-away hooks
-Rechargeable Li-ion battery
-Shatterproof polycarbonate tube
-Two brightness settings
-Comes with 12V cigarette lighter adapter and 120V wall adapter
Old Dec 4, 2013 | 01:14 PM
CharmzOTP's Avatar
WOW CRAZY BUILD WHATS YOUR POWER GOAL
done up bb6
Wheels
50
Mar 3, 2010 08:09 AM
EVIL_DC5
Northern California
69
Apr 5, 2009 07:18 PM
blackdc5
Sep 14, 2003 07:46 PM
integra_gsr98
Nov 25, 2002 08:27 PM
