TLC- Trick Lightweight Crankshaft...ultimate BLING BLING that PERFORMS!!
I am proud to introduce our sophisticated lightweight cranks and crank service.
We are very serious, professional and only produce very high quality work/engines. The work is not done offshore or Mexico, we do not use sweat shops or virtually free labour to produce anything we do. You cannot buy these cranks at Walmart https://honda-tech.com/forums/images/smilies/emwink.gif The cranks have been researched, developed and tested in-house. The Factory Honda crank forging has proven to be quite strong. I believe this to be a superior design to anything available anywhere, in a factory forging. This is not merely spun on a lathe and "knife-edged". The weight is strategically removed in a way that retains the torsional stiffness, while maximizing weight reduction and substantially decreasing windage losses. Zero deflection is experienced during the process. The Cranks are professionally balanced to ~0.5g Oiling holes are tear dropped chamfered for superior oiling properties. As an example, the H22 series cranks we have taken from 40 lbs to 33.5 lbs, or metric 18.0 kg to 15.2 kg. This makes a HUGE difference in Acceleration ! Offset grinding and big radius rod journals available. Ion PLasma Gas Nitriding also available. from this: https://i14.photobucket.com/albums/a...ckh22crank.jpg to this: https://i14.photobucket.com/albums/a...rankH22003.jpg https://i14.photobucket.com/albums/a...rankH22002.jpg https://i14.photobucket.com/albums/a...s/TLCH22-4.jpg Please email or call me with any questions that you might have. Thank you Frank Pocketrockets Racing website: http://www.pocketrocketsracing.com email: Frank@pocketrocketsracing.com phone: 1-613-802-0385 ( Eastern time zone North America) Hours : open 9 am- 9 pm Mon-Sat. Modified by PocketRockets Racing at 10:56 PM 11/15/2005 Modified by PocketRockets Racing at 11:06 AM 1/3/2006 |
Re: TLC- Trick Lightweight Crankshaft...ultimate BLING BLING that PERFORMS!! (PocketRockets Racing)
looks very nice.
Any reason you didn't remove material from the whole counterweights vs just the edges? Seems the rough texture would incourage oil sticking to it. |
where'd the other post go?
yea but how much does it cost?
Re: (Lekz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lekz »</TD></TR><TR><TD CLASS="quote">yea but how much does it cost?</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: TLC- Trick Lightweight Crankshaft...ultimate BLING BLING that PERFORMS!! (StyleTEG)
Looks good... https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
What is the benefit of Ion PLasma Gas Nitriding? Does this increase the torsional stiffness of the crank? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PocketRockets Racing »</TD></TR><TR><TD CLASS="quote"> You cannot buy these cranks at Walmart https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE> Blah, I've seen these cranks at K-mart, lol |
how much weight was removed from the crank shown. are there some cranks that this works better with (as in motor type)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PocketRockets Racing »</TD></TR><TR><TD CLASS="quote">I am proud to introduce our sophisticated lightweight cranks and crank service.
We are very serious, professional and only produce very high quality work/engines. The work is not done offshore or Mexico, we do not use sweat shops or virtually free labour to produce anything we do. You cannot buy these cranks at Walmart https://honda-tech.com/forums/images/smilies/emwink.gif The cranks have been researched, developed and tested in-house. The Factory Honda crank forging has proven to be quite strong. I believe this to be a superior design to anything available anywhere, in a factory forging. This is not merely spun on a lathe and "knife-edged". The weight is strategically removed in a way that retains the torsional stiffness, while maximizing weight reduction and substantially decreasing windage losses. Zero deflection is experienced during the process. The Cranks are professionally balanced to ~0.5g Oiling holes are tear dropped chamfered for superior oiling properties. As an example, the H22 series cranks we have taken from 40 lbs to 33.5 lbs, or metric 18.0 kg to 15.2 kg. This makes a HUGE difference in Acceleration ! Offset grinding and big radius rod journals available. Ion PLasma Gas Nitriding also available. from this: https://i14.photobucket.com/albums/a...ckh22crank.jpg to this: https://i14.photobucket.com/albums/a...g/TLCH22-4.jpg https://i14.photobucket.com/albums/a...g/TLCH22-3.jpg https://i14.photobucket.com/albums/a...g/TLCH22-2.jpg Please email or call me with any questions that you might have. Thank you Frank Pocketrockets Racing website: http://www.pocketrocketsracing.com email: Frank@pocketrocketsracing.com phone: 1-613-802-0385 ( Eastern time zone North America) Hours : open 9 am- 9 pm Mon-Sat. Modified by PocketRockets Racing at 10:56 PM 11/15/2005</TD></TR></TABLE> looks good man....here is a thought to.the f23 crank is 4-5lbs lighter stock untouched than the h22 crank.....what can you do w/the f23.do you think you could get the rotating mass down to that of a gsr crank. https://honda-tech.com/forums/images...s/emsmileo.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif harv |
Re: TLC- Trick Lightweight Crankshaft...ultimate BLING BLING that PERFORMS!! (1700anddroping)
That is bling!
wtf...where did Ed's post go??????
Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O »</TD></TR><TR><TD CLASS="quote">
Blah, I've seen these cranks at K-mart, lol</TD></TR></TABLE> but 7-11 has better prices on thses cranks then k-mart <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lekz »</TD></TR><TR><TD CLASS="quote">yea but how much does it cost?</TD></TR></TABLE> i would like to know this also |
Re: (92hondalude)
I am waiting to see a certain comment from the elite engine builders about a certain thing that was done here.
Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd »</TD></TR><TR><TD CLASS="quote">wtf...where did Ed's post go??????</TD></TR></TABLE>I didn't feel like being negative after I posted.I seemed to be the only one bringing it up,so....
Re: (Ed's Racing Heads)
i would like to add this. the reason why i am build a all motor h22 is because of the videos i saw for your h22 or should i say h27.
https://honda-tech.com/zerothread?id=1421212 (my build thread) I know mine will never be no where near as good as yours but hopefully it will be a car motor to drive. so far it has been fun just building it https://honda-tech.com/forums/images/smilies/emthup.gif thank you frank for inspiring me |
Very nice looking. Care to go into detail on why there is additional machining on the oil galley holes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads »</TD></TR><TR><TD CLASS="quote">I didn't feel like being negative after I posted.I seemed to be the only one bringing it up,so....</TD></TR></TABLE>
i don't think it was negative at all...it was honest and insightful |
Re: (rhd)
Thank's Rob,I guess I'm just getting tired of fighting w/people on Drama-Tech. https://honda-tech.com/forums/images...s/emsmilep.gif
haha.....maybe i'll get tired of it sometime....and get some points back
so..back to the crank.... is similar prep offered on other cranks, or are you JUST h-series? |
Re: (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">I am waiting to see a certain comment from the elite engine builders about a certain thing that was done here.</TD></TR></TABLE>
Such as the chamfering of the oil holes, the rounding of the trailing end of the counterweights and not just knife edging it. |
Re: (PURPLETERROR aka BIGMATT)
Or is that the leading edge of one should be the opposite of the other? Discuss.Nice piece.
Re: (DonF)
I figured a Cosworth engine builder would notice.
From what I've seen though Frank does some really good stuff with motors. https://honda-tech.com/forums/images/smilies/emthup.gif |
The oiling holes go through a number of other process before being finished.
here are a couple pics of of a crank having been gone through some rod journal work, finishing processes and the nitriding process. distortion free nitriding process, surface hardening process and provides more wear resistance. takes on the stealth look....lol....hiding the bling bling though lol. https://i14.photobucket.com/albums/a...itrided005.jpg Modified by PocketRockets Racing at 11:07 AM 1/3/2006 |
Re: (unusual71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unusual71 »</TD></TR><TR><TD CLASS="quote">how much weight was removed from the crank shown. are there some cranks that this works better with (as in motor type)?</TD></TR></TABLE>
6.6 lbs off this crank. "most" honda forged cranks can be processed. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">
looks good man....here is a thought to.the f23 crank is 4-5lbs lighter stock untouched than the h22 crank.....what can you do w/the f23.do you think you could get the rotating mass down to that of a gsr crank. https://honda-tech.com/forums/images...s/emsmileo.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif harv</TD></TR></TABLE> I do not bother with the factory pre 1999 h23 crank from the h23a engine.....its weaknesses have proven to be not so good a candidate. Some of the JDM H23A vtec 1999-2001 cranks I believe are as robust as the h22 cranks. I believe those can be brought in from Japan at around $700 each,new. that is the crank to use for a stroker H series, offsetting to 98mm. Billet cranks being the most expensive other option, obviously. |
