skunk2 tb install ?? throttle stop??
Old Nov 16, 2011 | 05:55 AM
cibao2ner's Avatar
Default skunk2 tb install ?? throttle stop??
i bough an used skunk2 pro 70mm tb...and it came with no tps and the throttle stop was missing...i bough it n got a tps from an old tb..now how do i adjust the butterfly and tps...since they are both loose?
if i adjust tps 1st then the readings will be off when i open/close the butterfly a lil more..
Old Nov 16, 2011 | 06:12 AM
Rosko's Avatar
Default Re: skunk2 tb install ?? throttle stop??
Set the tps close, adjust the stop till you are happy with the idle, then reset the tps to factory spec.
Old Nov 16, 2011 | 03:01 PM
Skunk2Brian's Avatar
Skunk2 throttle bodies have the butterfly bolts loctite in place. If the blade is loose thats a good indication someone has taken it apart before. Put the bolts back in with some red loctite and tighten everything up.
If you need a throttle stop email me at BrianN@skunk2.com and I will get you one. You need to install the throttle stop and set the butterfly so that it is as closed as possible WITHOUT touching the actual bore of the throttle body.
Once thats done you can set TPS. If you set TPS before setting throttle stop your settings will get skewed when/if you make any changes to the throttle stop.
Old Nov 16, 2011 | 03:11 PM
cibao2ner's Avatar
butterfly is fine..i already got a throttle stop from u guys...so just close it all the way and spin the stop a few turns till butterfly barely opens....gonna try that tomorow..
PR8urVtec
Sep 10, 2015 05:45 PM
slowEGles
Apr 6, 2014 03:39 PM
Slystone
10
Jul 21, 2008 06:43 AM
asefi944
Apr 11, 2005 09:43 PM
