Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series.
Old Oct 21, 2006 | 07:01 PM
  #26
b19coupe's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">What size exhaust do you run on the car? </TD></TR></TABLE>
On the street I run the Mugen which is about 2 1/2 ". Dynoed at the track on their Dynojet and made 240/156 on pump gas. Car ran a 12.7 @ 107 with a 1.7 60'. According to the track scales the car weighs 2600 lbs. with me in it.
Old Oct 21, 2006 | 07:06 PM
  #27
91' LS-VTEC's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote"> Car ran a 12.7 @ 107 with a 1.7 60'. According to the track scales the car weighs 2600 lbs. with me in it. </TD></TR></TABLE> good times, car seems a little heavy.
Old Oct 21, 2006 | 11:02 PM
  #28
an2ny888's Avatar
a bit ot.. how do you compute your ratio on the dynapack?
Old Oct 22, 2006 | 02:45 AM
  #29
b19coupe's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">a bit ot.. how do you compute your ratio on the dynapack?</TD></TR></TABLE>
FD times 4th gear ratio- or run the dyno and change the ratio in real time while watching the rpm readout on the laptop. As long as the ratio is close it has very little effect on the numbers.
Old Oct 22, 2006 | 08:28 AM
  #30
George Knighton's Avatar
H-T Order of Merit
Thanks for taking the time to post your graphs and followup. This will be useful in the future.
Old Oct 22, 2006 | 05:37 PM
  #31
b19coupe's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for taking the time to post your graphs and followup. This will be useful in the future. </TD></TR></TABLE>
More info:
Shawn's Dynapack dyno:
=DynoJet
In a street driven 91 octane 2600 lb. Integra.
Old Oct 22, 2006 | 07:38 PM
  #32
GUILOTINE's Avatar
Kill Gil
...no ******* joke
Old Nov 11, 2006 | 12:44 AM
  #33
A.E Motoring's Avatar
sick
Old Nov 21, 2006 | 11:38 PM
  #34
15sec's Avatar
SO basically Youll run pro 2s over pro 3s due 2 streetablilyt reliablity and POWER OUTPUT as well comfortablilty 2 tune it 2 its potential without worries?
Old Nov 22, 2006 | 09:52 AM
  #35
Skunk2Tony's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (15sec)
The pro 3 cam is too much cam for that motor setup. The difference between the two shown on the dyno graph is hardly anything and the differences between the two should be a lot greater with what we've seen. The pro 2 is the ideal cam for that motor.
Old Nov 22, 2006 | 11:03 AM
  #36
b19coupe's Avatar
Default Re: Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series. (Skunk2Tony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2Tony &raquo;</TD></TR><TR><TD CLASS="quote"> The pro 2 is the ideal cam for that motor. </TD></TR></TABLE>
That seems to be the case. I am very, very happy with the performance of these cams
Old Nov 23, 2006 | 06:26 PM
  #37
Black R's Avatar
25 Year Member
b19coupe, have you ever tried toda D's or toda spec C2's?
Old Nov 23, 2006 | 08:45 PM
  #38
b19coupe's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">b19coupe, have you ever tried toda D's or toda spec C2's? </TD></TR></TABLE>
I used to run Toda D's on motors that were not quite as well put together as my more recent engines. I have tuned a few customers cars with them. They are good cams and make great top end power.
Old Dec 6, 2006 | 06:28 AM
  #39
15sec's Avatar
Default Re: (b19coupe)
yo wassup man would...12.5.1 84.5mm b20 wit PRO series 3s WERK FINE..
Old Dec 6, 2006 | 06:32 AM
  #40
b19coupe's Avatar
Default Re: (15sec)
They will work. You just need to have plenty of piston to valve clearance to run them. The Pro 2's might be a better choice.
Old Dec 6, 2006 | 07:19 AM
  #41
Skunk2Tony's Avatar
Default Re: (15sec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 15sec &raquo;</TD></TR><TR><TD CLASS="quote">yo wassup man would...12.5.1 84.5mm b20 wit PRO series 3s WERK FINE..</TD></TR></TABLE>
Ported head? valve job? what kind of intake manifold and header are your running? The pro 3's move a lot of air and the rest of the motor has to be able keep up. Lots of compression will help as well
Old Dec 6, 2006 | 10:05 AM
  #42
BILLY_BLING's Avatar
I think I am going to trey the pro 2 on my b20 vtec street car
Old Dec 6, 2006 | 10:17 AM
  #43
Pondus's Avatar
Default Re: (Skunk2Tony)
What about a 2.1 L motor with 12.3 cr making 243whp on a set of Toda C's? Do you think the Pro 3's could give such a motor a good boost in power?
Old Dec 6, 2006 | 12:39 PM
  #44
Black R's Avatar
25 Year Member
Default Re: (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">What about a 2.1 L motor with 12.3 cr making 243whp on a set of Toda C's? Do you think the Pro 3's could give such a motor a good boost in power?</TD></TR></TABLE>
Based on your compression, I'd suspect that pro2's might net you some top end gains over your current setup.....
Old Dec 6, 2006 | 01:29 PM
  #45
Pondus's Avatar
I think so too, but I'm kinda wondering what a set of Pro 3's might do on my setup.
Old Dec 6, 2006 | 02:15 PM
  #46
Skunk2Tony's Avatar
Pondus, give me a call at the shop here, (951) 808-9888 and ask for Tony. I'd like to talk you a little more about your setup and help you out if I could.
Old Dec 8, 2006 | 04:30 PM
  #47
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">I think so too, but I'm kinda wondering what a set of Pro 3's might do on my setup.</TD></TR></TABLE>
I don't think your static c/r is high enough to make power with the pro3's..... your motor also REALLY needs to flow a lot of air to be able to take advantage of them.
Old Dec 14, 2006 | 03:57 AM
  #48
15sec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2Tony &raquo;</TD></TR><TR><TD CLASS="quote">Pondus, give me a call at the shop here, (951) 808-9888 and ask for Tony. I'd like to talk you a little more about your setup and help you out if I could.</TD></TR></TABLE>
I'm going 2 do the same
Old Jan 18, 2007 | 02:57 PM
  #49
pootie.teng's Avatar
hey are the drops during vtec x-over because vtec is set too low or is it always going to be there. i don't know anything about tuning but just wondering if there is anything you can do to not have that drop.
Old Jan 18, 2007 | 03:17 PM
  #50
b19coupe's Avatar
Default Re: (pootie.teng)
The dips are not at the VTEC transition and are due to intake/header combination.
