"Oils" Jobs in a motor.
Lets get some education going..
We all know oil is for lubication but whats "its" other job.. to lubericate and to...? Here's a hint, it helps cleans your engine. |
Re: "Oils" Jobs in a motor.
Detergents?
I would say oil performs a third function also as it helps to soak up some and I say "some" of the heat from the engine while in operation (like the BVTEC oil squiters acting on bottom of pistons) although unless your using an oilcooler to remove most of that convection then much of that heat is recycled through the engine as oil is pumped through it so theirs probably only a marginal cooling effects from the oil as the oil probably releases much of the convection near the galleys and uptop in the valvetrain area I would presume. |
this thread is not that informative..
Originally Posted by RaceCarRyne
(Post 40088161)
Why does oil turn black..? Whats oils other job besides to lubericate.. not hard if you think alittle bit.. i even gave you a hint. |
Originally Posted by DC_Legacy
(Post 40088094)
Detergents?
I would say oil performs a third function also as it helps to soak up some and I say "some" of the heat from the engine while in operation (like the BVTEC oil squiters acting on bottom of pistons) although unless your using an oilcooler to remove most of that convection then much of that heat is recycled through the engine as oil is pumped through it so theirs probably only a marginal cooling effects from the oil as the oil probably releases much of the convection near the galleys and uptop in the valvetrain area I would presume. Oil soaks some heat, your correct, but what else does it soak up.. |
Oil is a tremendous coolant. In the engine, the oil cools the underside of the pistons, valve springs, camshaft, rods, crankshaft and bearings. The oil picks up the heat from the combustion of fuel, as well as friction, and takes it away (no matter how good the oil may be, there is always friction). The volume of the oil in the crankcase helps transfer the heat, but where a car/truck is used in high temperature climates, for hauling trailers or heavy loads, an engine oil cooler is sometimes recommended.
Oil serves as a sealant, filling the microscopic ridges and valleys found in any metal surface, increasing the engine's efficiency |
Originally Posted by ALL M0T0R
(Post 40088281)
Your on the right track..
Oil soaks some heat, your correct, but what else does it soak up.. Reguarding detergents in oil heres an interesting comment on how having too little or too much detergent can be harmful with motor oils in some motors. "Inadequate detergent will result in gum and lacquer clinging to the hotter engine components - too much detergent can cause a build up of metallic ash in the combustion chambers of older engines. In older engines with traditionally high oil consumption, this will cause detonation and pinking. In older engines where the carbon has built up over a number of years the detergents can also have a scouring effect causing the carbon to flake off, blocking up oil galleries and spray jets. High levels of detergent will "wash" traces of carbon from seals and gaskets, revealing oil leaks." http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9014112&conten tId=7027140 |
Hate to be "ignorant" and a "kid"
But, seems like the OP is getting his education from the community. Thanks for starting the thread either way. |
Originally Posted by BeniRacing
(Post 40088592)
(Post 40088624)
Negative, he's just trying to strike up an intelligent discussion by asking questions first as most who come through this forum are only looking for quick anwers and solutions to their current situations/problems and rarely want to have discussions on their own understandings or findings.
(Post 40088592)
But, seems like the OP is getting his education from the community. Thanks for starting the thread either way. Every reply to any thread, is always ignorant from you.. you have it set in your head that your always right and everything you say is just.. that.... i'm trying to start a intelligent conversation. I know about oil.. and what it does and how it works.. majority of this community are asking questions.. "which oil do use in this motor" Well this discussion is for that. Oil isn't just a lubericate. If you knew anything you'd know your oil cleans your engine.. it soaks up dirtiness from the motor ... Why do you think oil turns black? Its not because your motors dirty neither.. its from gas getting into the oil.. Oil plays a huge part in an engine and alot bigger then most realize. Anyone know the difference between regular oil and syn? |
(Post 40088876)
Without looking it up, I believe synthetic oil has a better or specifically refined molecular structure to help prolong breakdown from shearing and heat that contributes to longer uses between change intervals as far as my understanding... |
What good is oil if it last forever, its all about the money IMO. But yes oil cools and cleans the motor.
(Post 40088876)
Every reply to any thread, is always ignorant from you.. you have it set in your head that your always right and everything you say is just.. that.... i'm trying to start a intelligent conversation. I know about oil.. and what it does and how it works.. majority of this community are asking questions.. "which oil do use in this motor" Well this discussion is for that. Oil isn't just a lubericate. If you knew anything you'd know your oil cleans your engine.. it soaks up dirtiness from the motor ... Why do you think oil turns black? Its not because your motors dirty neither.. its from gas getting into the oil.. Oil plays a huge part in an engine and alot bigger then most realize. Anyone know the difference between regular oil and syn? Pronunciation: \ˈig-n(ə-)rənt\ Function: adjective Date: 14th century 1 a : destitute of knowledge or education <an ignorant society>; also : lacking knowledge or comprehension of the thing specified <parents ignorant of modern mathematics> b : resulting from or showing lack of knowledge or intelligence <ignorant errors> 2 : unaware, uninformed I have correct information and knowledge.... The jobs of motor oil are to clean, cool, seal and lubricate. Hard to be ignorant when I am "Informed" |
(Post 40088548)
Carbon deposits? As far as the blackening of oil I've also understood the breakdown process of oil to be a combination of heat and molecular shearing from fast moving parts within an engine.
My reasoning would be gear oil (85w-140). When it gets old and needs to replaced it doesnt really turn black, so i would think that something in the engine would also contribute to oil turning black. Granted, motor oil likely sees much higher temps than differential's do on trucks, awd cars, etc. |
Originally Posted by h22ej8
(Post 40090859)
I'll be honest, i know little about exactly what all oil does. However, i don't understand this logic.
(Post 40090407)
Main Entry: ig·no·rant
Pronunciation: \ˈig-n(ə-)rənt\ Function: adjective Date: 14th century 1 a : destitute of knowledge or education <an ignorant society>; also : lacking knowledge or comprehension of the thing specified <parents ignorant of modern mathematics> b : resulting from or showing lack of knowledge or intelligence <ignorant errors> 2 : unaware, uninformed I have correct information and knowledge.... The jobs of motor oil are to clean, cool, seal and lubricate. Hard to be ignorant when I am "Informed" For the betterment of this discuss and the forum reguardless of how big of a twatrag i think you are.. i'ma not fight with you, every thread i'm in you always have something to say, if its logical and contributes to the subject great.. stop taking cheap shots at a person over the internet.. its quite annoying and childish. |
(Post 40090859)
My reasoning would be gear oil (85w-140). When it gets old and needs to replaced it doesnt really turn black, so i would think that something in the engine would also contribute to oil turning black. Granted, motor oil likely sees much higher temps than differential's do on trucks, awd cars, etc. What I was unsure of is if the breakdown from heat and shearing from moving parts contributed to its blackening as well. |
(Post 40091364)
I should have worded that differently. I'll be the first to say that I know about as much as any average joe when it comes to oil (with a fair understanding of viscosity grades), so with that said the blackening is probably due to carbon from the motors combustive process and fuel as ALL M0T0R mentioned.
What I was unsure of is if the breakdown from heat and shearing from moving parts contributed to its blackening as well. Its because they can do _____________ what better then regular oil ;) |
Last 2K mi longer between change intervals over conventional?
(Post 40091404)
Answer : syn oil allows for more cooling, lubing while picking up and cleaning more of the engine.. It allows for more "soaking up" Your right on the combustion process making the oil black.. as well as some gas getting in the oil.. But your right This is not saying that convential oil isn't good, compared to syn people have perferences.. but this is a good explaination of why syn oil is better then convential oil.. Majority of the time its perference. |
(Post 40091481)
It does last long.. but why..
Answer : syn oil allows for more cooling, lubing while picking up and cleaning more of the engine.. It allows for more "soaking up" Your right on the combustion process making the oil black.. as well as some gas getting in the oil.. But your right This is not saying that convential oil isn't good, compared to syn people have perferences.. but this is a good explaination of why syn oil is better then convential oil.. Majority of the time its perference. Question though, were did you learn of synthetic doing a better job with cooling? |
(Post 40091592)
It accomplishes this through a reduction in friction which in turn reduces temperatures. It doesn't cool like coolant would, in a thermal transfer way, any better than a conventional oil would.
(Post 40091364)
Originally Posted by 00Red_SiR
(Post 40091791)
All this talk on oil has me searching for idependant studys comparing the two again which I havent researched since I did a speech report on motor oil in college well over a year ago. |
