Jesusbernal249's LSVTEC build thread: what to do next?
So i have this lsv thats running at 185 hp. I know thats good hp especially for a hatchback but I wanted to get it up to 200 hp. Any suggestions of what I can add on?? Yes ive searched throughout the forum but everyone talks about NA B20vs instead of LSvs
im running with -greedy headers -hookups manifold -eagle rods -CTR pistons -pr3 head -b18b block -thicker headgasket -3" full exhaust straight pipe |
re: Jesusbernal249's LSVTEC build thread: what to do next?
Skunk2 pro1 / buddy club spec 4 / similar to those nature cams
Ported head E85 fuel 3" exhaust dyno tuned |
Originally Posted by KiNGDEE206
(Post 51675018)
Originally Posted by Jesusbernal279
(Post 51675125)
sorry i forgot to say but i have the 3" full exaughst straight piping and running with a ported head on ctr pistons. I'd basically just add the bigger cams but I read I'd have to upgrade my retainers and valve springs as well. Is that correct??
Originally Posted by ontariorider
(Post 51675186)
ofcourse you will need to upgrade the vt when u swap to aftermarket cams |
I made right at 200whp on my LS/V setup, here's my specs:
B18b Block bored to 81.5mm B16 Head (stock port) 5 angle valve job ITR valvesprings Crower 402-A2 cams USDM ITR pistons (NPR) Reconditioned B18b rods with ARP rod bolts ACL Race bearings, rod and crank PLM Tri-Y 2.5" header to 2.5" exhaust DSM 450cc injectors Blox ITR-rep intake manifold 68mm Professional Products throttlebody 3" short ram intake tubing with Blox 6" velocity stack/filter combo Tuned on CROME on a DynaJet chassis dyno Made 199whp, 137ft/lbs on 93 octane gas. |
Originally Posted by DumpdEJ6
(Post 51675808)
if youre at 185 without a tune go tune it
ull probably end up being 190-200Whp |
Find some Crower 402-2 or 403-2 and tune it on e85. You'll love it! 🤗
