Feedback request: Vtecthatcould's B20VTEC EG hatch build progress
currently i got a 95 EG hatch current mods list is
B16a3 GSR transmission b16 intake mani gsr suspension all the way back (control arms, sway bars, struts,) energy suspension bushings all the way through. Generic CAI half size radiator gsr brakes my weight reduction as of now consists of just front 2 seats, removed front and rear bumper support, all interior and plastic is gone dash is gone heater core all that gone, no PS/AC, (looking at cutting the doors, shaving metal and lexan windows after the cage goes in. also heard Ktuned rear trailing arms shave about 50 lbs off but theyre expensive as FUCK. the goal is 1700 LBS fully gutted from top to bottom ( ive been asking a few buddies i know that weld and seeing if i can find anyone willing to weld in a cage, on a side note this will be extremely gutted mainly for track use) i had bought this car before i knew too much about cars and after i had bought it 2 years ago i found out the motor is stolen . . . motor vin shaved off but trans is still legit so i am looking into storing the b16a3 block and keeping that as a last resort block . . . i had bought a blown up gsr from my uncle for 10 dollars . . . cylinder 1 has a huge crack but that seems to be it and the head is also unusable . . . but i have bnib ITR pistons from honda . . . i have been debating between b20v or resleeving the gsr block and building a poor mans type r . . . i do eventually plan to cruise this around and slay some street cars here and there . . . i have been leaning towards b20v mainly due to the cost to resleeve . . . cost has come into play i now have a kid on the way . . . so budget is key . . . and i know many of you build amazing cars on a tight budget . . . my b20v build list so far b20 block (unsure if i should look into boring and honing to 84.5 for the smoothness or rock the stock sleeve at 84) also 250 for a longblock from my local junkyard golden eagle conversion kit gsr trans 750-1000 cc injectors (rc/grams) skunk2 pro 2/3 cams (some cam gears aswell) possibly hondata arp rod bolts,headstuds manley H rods YCP pistons high comp port&polish intake and matched to the head e85 dual bosch 044 fuel pumps still unsure of my exhaust ( have a rusty knockoff) micropolish/rebalance b20 crank ACL bearings skunk2 valvetrain (high comp)/ seals ( was also looking at the supertech) also looking at replacing all the pumps and seals and gaskets the goal here is Budget - $5,000 HP goal - 240 hoping to possibly squeeze that out on that budget . . . thoughts? should i opt in to resleeve the gsr and boost? the racecar is not number 1 priority anymore as i have a child on the way any thought would be appreciated . . . also looking at spray like a 75 shot on a b20v high compression i feel like you would have torque and power all the way through |
re: Feedback request: Vtecthatcould's B20VTEC EG hatch build progress
Rather unfortunate you're on a GSR gearbox, a B16 trans or even better 98+ ITR trans with the 4.7FD would be great for you.
You're going way overkill on fuel pumps and overcomplicating it, and spending much more than needed. For an all motor build a single 255lph fuel pump will suffice with E85, just make sure the pump is ethanol compatible. If you intend to rev the engine past 8500 or so I would also invest in a girdle setup. You could use the oil assembly (pickup, pan, main caps) from the blown GSR engine from your uncle and save a bit of money there on the installation. Golden Eagle makes a 3 way brace girdle, and there are also cheaper options on ebay. You will need to get the block align honed for a proper installation. I'd recommend saving your money and not investing in sleeves for the engine. With that being said, I would consider using a B18B/LS block instead of the B20 simply because the stock sleeves on the B18 engines are better than the B20s, especially once the B20 has been bored out to 84.5mm. Not saying the B20 wouldn't work, but you'd only be making a minor sacrifice in cylinder bore and have a bit more security with an LS block. Don't waste your money getting anything ported and polished. Make sure your intake/throttle body/intake manifold are port matched (just use a gasket & dremel with them off of the car), but don't waste your time/cash with the runner inlets or the cylinder head itself. If you use the Nippon Racing or YCP B16B/CTR piston replicas, I think you'd get around 12.6 -> 12.8 compression with an LS or B20VTEC setup (pretty sure that's the most aggressive compression piston they make for the B's). Unless you upgraded your intake manifold to something like an S2 Ultra Street, or at least a S2 Pro with a 70mm TB, I'd recommend sticking with the Pro 2 cams. With your compression ratio and the E85 fuel, you could probably tune the car to respond well to the Pro 3's, but I don't think it would be worth it if you stick with an OEM intake manifold. |
Re: Feedback request: Vtecthatcould's B20VTEC EG hatch build progress
unless you already have dual 044's theres no need for them at the power youre shooting for.
i make 240+ on a single 255 on pump e85. |
i think ill be going with a LS block with the USDM ITR pistons. on a side note would im interested in nitrous . . . nothing extreme id like to just have the extra oomph incase i get into trouble . . . like a 50-75 dry shot.
this isnt a daily driver but will see some street. |
Update: buying a LS block from a buddy of mine. i intend to run my b16a3 head on the block with P73-AO pistons, ill be looking into S2 Pro2 cams. from there i plan on getting the valve train built along with new seals. and for intake i would be looking into port matching. i wanted to redo my clutch and flywheel aswell at this point would it be beneficial to look into a LSD maybe looking into a type r trans. after that i will be grabbing a new fuel pump and injectors im thinking 750s..
im trying to keep this under $5,000 for now including fuel management and tuning im still shooting for 220 seem possible? |
Originally Posted by Vtecthatcould
(Post 51673230)
(Post 51673230)
im trying to keep this under $5,000 for now including fuel management and tuning im still shooting for 220 seem possible? I support the idea of trying to sell the GSR gearbox and getting a B16 or ITR gearbox instead, if possible. 750cc injectors will be fine, make sure they're E85 friendly. Don't cheap out with the EMS/engine tuning. Get Hondata or Neptune RTP. |
Originally Posted by Chance EG
(Post 51673340)
Change your piston selection to B16B/CTR pistons (both YCP and Nippon make them) and then yes, seems possible.
Originally Posted by TheShodan
(Post 51673395)
If you're going through the trouble of that. Keep the GSR trans. You never know how bad the next trans would be. Just add a good helical LSD on top what you have, and keep going with the substitute pistons. Try out what you have first, then make changes as needed.
yeah i was trying to utilize the pistons i have already (P73-AO) and arent the pro 2 cams similar to ITR cams or are they the pro 1s? i was also playing around with the idea of getting a CTR/ITR cam on the intake side and using a spare GSR exhaust cam (should be similar to that of the ITR exhaust if im not wrong) yeah i was also looking at the Mfactory helical and throwing that in my GSR or ditching the GSR trans for a B16 trans and throwing the Mfactory in.
i think ill be going with the supertech valve train package also |
also thank you everyone on this so far all of you have given useful opinions and advice! great to see not everyone is an asshat.
(Post 51675849)
i think ill be going with the supertech valve train package also 2. Do not mix camshafts like that. you're not supercharged., and will not find any advantage (the GSR is not similar to the CTR or ITR). Pro2s and Pro1s are nothing like CTR camshafts. Only the Tuner 1 series is close to that. Check Skunk2's website so you know what camshaft belongs in the hierarchy. 3. Make sure you know which supertech valvetrain you plan to use. If you plan to use an aggressive camshaft later, you want the HD series (85lbs spring seat pressure). Most places that sell a Supertech "package", don't use the HD series as default. So, verify before you buy. 4. Those pistons don't make the compression needed to make that power, but can still be fun to drive. Keep the camshaft simple with a Tuner 1 and enjoy what you get if you must keep the pistons. |
dont need to use the pistons but its the budget friendly way
(Post 51676099)
hey guys any of you guys into the h2b . . . im interested as stock for stock it would put more power out than my b16,b18
also seems to be decently cheap |
(Post 51680484)
just kinda interested seems like a solid deal since im already B
