Example Engine Build Sheet
An engine build sheet I put together. I thought I would share. I have it in an Excel file but pasted it here.
Engine Build Sheet
Inspected By:
Date:
Temp:
Block
Manufacturer
Model
Cylinder Bore Dia. #1 #2 #3 #4
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Main Bore Dia. #1 #2 #3 #4 #5
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Main Bore Dia. w/
Bearings Installed #1 #2 #3 #4 #5
Measurement #1
Measurement #2
Measurement #3
Crankshaft
Manufacturer
Model
Main Journal Dia. #1 #2 #3 #4 #5
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Rod Journal Dia. #1 #2 #3 #4 #5
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Pistons
Manufacturer
Part No.
Outer Dia. #1 #2 #3 #4
Manufacturer Spec.
Measurement
Pin Dia. #1 #2 #3 #4
Manufacturer Spec.
Measurement
Piston Rings
Manufacturer
Part No.
1st Ring Gap #1 #2 #3 #4
Manufacturer Spec.
Measurement
2nd Ring Gap #1 #2 #3 #4
Manufacturer Spec.
Measurement
3rd Ring Gap #1 #2 #3 #4
Manufacturer Spec.
Measurement
4th Ring Gap #1 #2 #3 #4
Manufacturer Spec.
Measurement
Rods
Manufacturer
Part No.
Big End Dia. #1 #2 #3 #4
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Small End Dia. #1 #2 #3 #4
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Big End Dia. w/
Measurement #1
Measurement #2
Measurement #3
Rod Bolts
Manufacturer
Part No.
Torque Spec.
Lubricant
Rod Bolt Length #1 #2 #3 #4 #5 #6 #7 #8
Manufacturer Spec.
Measurement
Rod Bolt Length
After Torque #1 #2 #3 #4 #5 #6 #7 #8
Manufacturer Spec.
Measurement
Main Bearings
Manufacturer
Part No.
Bearing Thickness #1 #2 #3 #4 #5 #6 #7 #8 #9 #10
Manufacturer Spec.
Measurement
Rod Bearings
Manufacturer
Part No.
Manufacturer Spec.
Measurement
Clearances
Piston - Wall #1 #2 #3 #4
Manufacturer Spec.
Calculation
Main Oil #1 #2 #3 #4 #5
Manufacturer Spec.
Calculation
Rod Oil #1 #2 #3 #4
Manufacturer Spec.
Calculation
Piston Pin Oil #1 #2 #3 #4
Manufacturer Spec.
Calculation
NOTES
Here is the Excel file: http://www.rndauto.com/engine_build_sheet.xls
Engine Build Sheet
Inspected By:
Date:
Temp:
Block
Manufacturer
Model
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Main Bore Dia. w/
Measurement #1
Measurement #2
Measurement #3
Crankshaft
Manufacturer
Model
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Pistons
Manufacturer
Part No.
Manufacturer Spec.
Measurement
Manufacturer Spec.
Measurement
Piston Rings
Manufacturer
Part No.
Manufacturer Spec.
Measurement
Manufacturer Spec.
Measurement
Manufacturer Spec.
Measurement
Manufacturer Spec.
Measurement
Rods
Manufacturer
Part No.
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Manufacturer Spec.
Measurement #1
Measurement #2
Measurement #3
Big End Dia. w/
Measurement #1
Measurement #2
Measurement #3
Rod Bolts
Manufacturer
Part No.
Torque Spec.
Lubricant
Manufacturer Spec.
Measurement
Rod Bolt Length
Manufacturer Spec.
Measurement
Main Bearings
Manufacturer
Part No.
Manufacturer Spec.
Measurement
Rod Bearings
Manufacturer
Part No.
Manufacturer Spec.
Measurement
Clearances
Manufacturer Spec.
Calculation
Manufacturer Spec.
Calculation
Rod Oil #1 #2 #3 #4
Manufacturer Spec.
Calculation
Manufacturer Spec.
Calculation
NOTES
