dzminiz's D16 Engine Rebuild Kit
i spun a bearing so im lookin toward a rebuild kit, as long as i didn't bend anything, so new bearings, oil pump, ANY1 Know Where To Find A Kit??
Thanks |
Re: d16 rebuild kit (dzminiz)
i dont know if anybody sells a complete rebuild "kit" but you can pick up some ACL bearings from a couple different distributors on this site, one of them being EARL. you can pick up a gasket set and oil pump from your local honda dealer. hope that helps a little. maybe somebody else has some pointers about where to pick up gaskets for a better price. https://honda-tech.com/forums/images/smilies/emthup.gif
Any1 Have Any Links or More Info For Me?? https://honda-tech.com/forums/images...es/emsmile.gif
THANKS |
exactly what other parts would i need??
http://www.importperformanceparts.net offers alot of rebuild parts, like higher-flowing oil pumps and bearings
http://www.hondaautomotiveparts.com is a decent source for parts, i know their sister site acuraautomotiveparts.net offers honda part for 25% off OE list.... |
Re: (dzminiz)
if you spun a rod bearing, the crank is going to need to be checked out, to see if you ate the journal up.
i can sell you a package deal that will give you a great basis for an all motor d16. if all you need is bearings, pistons, rings, pins, and a gasket kit, off the top of my head i could sell it for $500. |
Re: (CallMeJesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CallMeJesus »</TD></TR><TR><TD CLASS="quote">if you spun a rod bearing, the crank is going to need to be checked out, to see if you ate the journal up.
i can sell you a package deal that will give you a great basis for an all motor d16. if all you need is bearings, pistons, rings, pins, and a gasket kit, off the top of my head i could sell it for $500.</TD></TR></TABLE> Why would he need new pistons? |
Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Why would he need new pistons?</TD></TR></TABLE> for a bump in compression he could select a set of OE pistons from another d, such as p29 or something----- |
Re: (builthatch)
dude here's some advice, drop the d-16 and why dont you get some B series motor? sounds like some extra horse power, reliable, and you get more street credit dawg, haha im kidding, you got to think what is more worth your money
Re: (S13sGA2DUMP)
full d16z6 build for $2500 with 90% OE honda parts that will net you around 20-25 more whp and 20+ more ft/lbs than a b16 swap...or, b16 swap with all the associated parts for $2500.....
Re: (builthatch)
d16z6 build for $2500...ill tell you what, ill do that build for $1500, all day long, any day of the week including God's day.
i built a d16z6 for a thousand. it runs nearly 14:1, eats up b, h, and k series engines with a jg engine dynamics cam, and TB. i love b series, but there is a lot to be done with a d16. but the next trick is droppin a fully built turbo h22a runnin 11:1 with 16lbs into a 1988 crx si shell. |
Re: (CallMeJesus)
to make over 150 whp reliably out of a sohc vtec, I have found you need...
p29's @ .5mm over with rings- 250 Crower 2 or 3 cam- 325 Springs/ TI rets- 320 ARP rod bolts- 50 Bore, mill/deck, balance, shot-peen rods, valve job- 500 portwork- free, if you know what you are doing or portwork- 500 bearings, gaskets, WP/t-belt- 250 Clutch- 325 y8 intake mani- 50 BBK TB- 250 or Type R TB- 150 Header- 300-600 PowerFC- 650+250dynotime or Hondata- 295+250 dynotime or chipped p28- 150 This is assuming you already have the complete engine and it is not damaged, your fuel pump is up to the task, your injectors are balanced/ flowing properly, and already have obd1 harness plugs so you don't need jumper harness.... PS- sure, you could cut many many corners, but every extra mile you get out of the setup is worth it as is every little HP... |
i just did the same thing looking for same info and if you find anything please let me know, i need to get my car back on the road
thanks tangy.. |
Re: d16 rebuild kit (NA tangy_b16)
wow this topic is OLD>
I just swapped in a gsr https://honda-tech.com/forums/images/smilies/emsad.gif Wish i would've stayed sohc (moneywise) or bought another car and built a motor as the money was availbale. just my .02 |
re: dzminiz's D16 Engine Rebuild Kit
Hey guys. yeah this is really old post but i thought i just share it anyways for the people that are still looking for a rebuild kit. http://ebay.to/2FEhEWY Bought this rebuild kit and it did the job for what i need it for.
