CODE # 9 PLEASE HELP
Old Jul 6, 2007 | 04:33 PM
ys1civicsi's Avatar
Default CODE # 9 PLEASE HELP
Ive been reading code 9 is a bitch to get rid of, I have tried 2 good distributors My setup is an Ls/vtec Blox cams USDM type-r Pistons head is milled .20 and the typical bolt ons. I have it all jumped to OBD-1 in a 91 Si hatch. Can Anyone help me i have tryed everthing from a new distributor to adjusting the cam gears and checking the wiring what Am I doing worng please let me in on your secrets Thanks guys
Old Jul 6, 2007 | 05:25 PM
foumer's Avatar
W95 gives me a hard-on
Default Re: CODE # 9 PLEASE HELP (ys1civicsi)
did you check the wiring between the distributer and the ecu. Maybe you have a dead wire.
Old Jul 7, 2007 | 02:30 AM
ys1civicsi's Avatar
Default Re: CODE # 9 PLEASE HELP (foumer)
That Is what i am going to tackle when i get home from work today, I will trace the wires from the ecu to the distributor and see what i find out, Maybe I will even wire the distributor straight to the ECU just to rule out if there is a dead wire or not Do you know the other 5 pins where the distributor comes into the ECU the cps is B15,B16 thanks for your help
ys1civicsi
Jul 7, 2007 06:19 PM
extensioncordy
10
Oct 30, 2006 07:21 AM
v8hnta
Jul 13, 2006 11:21 AM
Sobe_Death
Mar 11, 2004 10:09 AM
