All motor Nissan setup and numbers
Figured I would post up and get some feedback on my current build Nissan sentra.
Not a Honda but can easily be compared to the K24 series motor, VTEC and all. Looking for ideas on what you guys used for intake manifolds, header size/specs etc. There is no aftermarket support for these motors so everything has to be custom. ASP started designing parts for me but it never made it to completion. Shouts to Stefan and crew, hope all is well... SR20VE (bored 6mm over) Now 2.4L CP 12.5:1 Pistons Eagle Rods Ported & Polished head (flows 380+cfm @ .5" lift) Supertech Valves, Springs & Retainers Mazworx knifed edge 92mm crank Custom 4-1 header Stock Intake manifold (still being custom made) Stock Cams (still being custom made) Blue was my stock 2.0L setup with bolt ons, Red is the current build with stock IM and cams. http://img.photobucket.com/albums/v7...K/69a21406.jpg http://img232.imageshack.us/img232/9639/img0644q.jpg http://img217.imageshack.us/img217/9439/img0459e.jpg http://img190.imageshack.us/img190/2745/ve8lx.jpg http://img696.imageshack.us/img696/3832/ve10.jpg http://img838.imageshack.us/img838/9473/ve9o.jpg http://img121.imageshack.us/img121/6857/ve4t.jpg http://img88.imageshack.us/img88/5181/qr252.jpg http://img820.imageshack.us/img820/2510/ve2e.jpg http://img23.imageshack.us/img23/1236/ve12.jpg http://img517.imageshack.us/img517/3023/ve5i.jpg http://img695.imageshack.us/img695/904/ve1v.jpg http://img121.imageshack.us/img121/993/39749455.jpg http://img29.imageshack.us/img29/5702/24ve.jpg |
Re: All motor K series killer
Another dyno sheet of my buddy's simular build with custom intake manifold, smaller 2.25 in collector 4-1 header.
http://img.photobucket.com/albums/v7...K/32201002.jpg |
definatly some nice numbers..i told my cousin about your build....he has a sr20ve that he blew and wants to do it all motor...were are you guys located?
damn...i way to think outside the box....would love to see the faces of people when you blow by them....in a sentra...lol
ves are garbage ;) .
stratton. |
14:1 compression and e85
Do these motors require sleeving? Really impressive, seems like theres alot more left in it.
so let me get this straight. You're comparing your stroked, decked setup to stock crank k24's with stock stroke and deck? Nice.
Not taking anything from the build but k24's can achieve that goal quite easy with mostly off the shelf or for what ive seen oem bottom end setups. If your going to call it a k-series killer your going to need to come to the table with a bit more than that. |
Originally Posted by The Ogre
(Post 44899210)
Not taking anything from the build but k24's can achieve that goal quite easy with mostly off the shelf or for what ive seen oem bottom end setups. If your going to call it a k-series killer your going to need to come to the table with a bit more than that. This is a AEBS sleeved block with the stock deck. We cant use deck plates like hondas to use larger cranks. You fail to realize K20/K24 motors use a longer rod and have a better rod ratio being a under square motor. Our stock stroke is 86mm. To achieve what we have achieved on a square, shorter stroke motor says alot. Putting HP to the side, look at the TQ. With small cams/IM we are putting down more TQ than worked K24's, not to mention doing it on 93 pump. |
lol that was a torque plate or hone plate, only used during the machining process to simulate the internal stresses caused by torquing down the head
more pics of the intake and exhaust ports? |
if you come here to talk trash...I like your build man but no need to sh*t on k series.I dont know if we can see a k20 past the 300whp barrier with the stock 86mm stroke.
nice build, now get a decent intake manifold on that thing and make another 20whp!
And this is no longer 86mm stroke, its a square 92x92. I don't think he is on here to talk trash, its just nice to see nissan has something to keep up w the big h and k guys! |
As I said over on K20a.org, im having a hard time believing 2446cc with only 12.5:1 compression and a cam that is comparable to a stock K20a2 cam, can make 240lb/ft of torque at the wheels.... just doesnt add up imo
Originally Posted by Jmarsh
(Post 44906279)
Decked setup?
Dyno numbers are just that, numbers. Put up the real numbers at the track. IE: He could say it makes 400hp n/a but then run an 11.5. Track tells the truth. None the less this is quite impressive.
380+ cfm at .500 lift? Any proof of that. Nice build tho.
Originally Posted by J35monster
(Post 44916062)
Originally Posted by Professor15
(Post 44916317)
(Post 44916330)
Not necessarily track numbers, but trap speed. Then this thing should be trapping in the high 110's/120 mph rage.
K killer. Uh no way! You're barely making 300 hp. The K's are making 350+ WHP. Shit even the lil B series are making the same power you are with only 2.2 liters. I have an idea, although I don't race any of the all motor shootouts I'll gladly put $100 towards your entry fee to go race in it. I want to see you go and kill some K's.
Originally Posted by lunatics209
(Post 44917001)
This is why it is even pointless to post anything on most boards. The point was not to start a piss match over Nissan Vs. Honda but to open eyes. Mod for mod, these motors are making more WHP/TQ on pump gas. If you read you will see that it made that power on a stock intake manifold with the factory 60mm TB. The car also has factory cams in it. I made the header with a smaller choke than it was spec'd for so there is plenty on power to be made while still staying on 93 pump. Mods please delete this thread. I already see it heading downward. |
(Post 44917407)
(Post 44917001)
(Post 44917407)
I love the fact the you do not have a clue.
This is why it is even pointless to post anything on most boards. The point was not to start a piss match over Nissan Vs. Honda but to open eyes. Mod for mod, these motors are making more WHP/TQ on pump gas. If you read you will see that it made that power on a stock intake manifold with the factory 60mm TB. The car also has factory cams in it. I made the header with a smaller choke than it was spec'd for so there is plenty on power to be made while still staying on 93 pump. Mods please delete this thread. I already see it heading downward. Shoulda just made a thread in the all motor section, showing it off maybe then you would get the props and approval you are looking for. Just saying though. |
Lets not jump down his throat folks. I'm pretty sure the title was meant to be in jest. I can change it if it would get everyone's panties out of a twist.
BTW, I don't recall seeing any K motors making 350+ whp on pump gas. Can someone link me? |
Originally Posted by rochesterricer
(Post 44917846)
