Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
emblems
Old Jul 11, 2006 | 02:02 PM
vincent001's Avatar
Default emblems
where can you get the jdm emblems for the 02 tl... "inspire"
want to jdm the car out so what can i do?
Old Jul 11, 2006 | 02:32 PM
accordselux's Avatar
Me Gusta History
Default Re: emblems (vincent001)
http://www.aj-racing.com/catalog/home.php?cat=54
Old Jul 11, 2006 | 03:15 PM
vincent001's Avatar
thanks for the quick reply... gonna order them some time this week!
Old Jul 12, 2006 | 11:31 PM
mrnewguy's Avatar
* B A N N E D *
i want to remove all badges including the A.
do i bondo it and go find a paint marker same color
please list exact steps if you cant.
Old Jul 13, 2006 | 06:41 AM
Me Gusta History
Default Re: emblems (mrnewguy)
Try to shave it off with a razor blade (the TL emblems are just glued on), but be careful to not scratch the paint. Then use 3M adhesive and wax remover to remove the adhesive and it should be good. BOndo is probably the best solution, but i've had crap results with the paint pens when i've done touchup so it may not be the best plan, but it would look a lot better than 2 holes, and they won't rust that way
Old Jul 14, 2006 | 06:15 PM
Tientruong's Avatar
DOnt use a razor blade!!! use heat gun, and dental floss, then buff the paint near it with goo off or adhesive remover.
Old Jul 14, 2006 | 08:14 PM
CmptchAV6's Avatar
Default Re: (Tientruong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tientruong &raquo;</TD></TR><TR><TD CLASS="quote">DOnt use a razor blade!!! use heat gun, and dental floss, then buff the paint near it with goo off or adhesive remover. </TD></TR></TABLE>
I always use a screwdriver and a hammer when removing emblems
j/k
Heat gun and dental floss is the best method. When I have done this I typically just pull them off by hand on a hot summers day after the car has been sitting in the sun for a while. Then again I live in FL so a heat gun would probably cool the adhesive.
JScott3d
Paint and Body
Feb 29, 2008 01:02 PM
Chez'sExCoupe
Apr 10, 2005 11:01 AM
akteamster
Dec 18, 2004 02:01 PM
getfast
24
Nov 27, 2001 06:53 PM
