Fuel Return DIY
13 Attachment(s)
stock RSX fuel system uses a single fuel line to the stock fuel rail, it pressurizes this rail to stock fuel pressure of 43-47PSI. It has an un-adjustable FPR in the stock fuel cage in the tank.
When you add boost to any engine, you need to be able to increase fuel pressure to match what the intake manifold/supercharger manifold is seeing. For example, if you put 15PSI into an engine, the stock fuel system is pushing fuel at 43psi. So the engine side of the fuel injector is seeing 15psi, so now you're down to 28psi on the fuel rail. 43-15=28psi. The less fuel pressure provided to the injector, means the injector needs to stay open longer to provide the needed fuel to the engine. More boost = larger fuel requirement. You can start to see the problem here. your injectors will run a much higher duty when in boost with the stock fuel system. Even with an upgraded pump you won't get around this. when you add a return line and a 'full fuel system' you provide much more fuel to the fuel rail at all times, also the fuel pressure regular will increase fuel pressure at 1:1 rate. You run a boost line from the intake manifold into the fuel pressure regulator and as intake pressure rises, the outlet hole in the FPR gets smaller, thus making the fuel trying to escape become more pressurized. Any excess fuel that the pump is pumping from the tank returns back into the tank to make the trip again. I hope this better explains it for everyone. So today even though I’m busted up from surgery I decided I would finally finish my fuel system. I had pretty much been done and just awaiting some new parts from Hybrid Racing. There are a lot of parts involved in doing a full fuel system with return line. This process is not cheap. I’ve seen people spend up to $1k in just their fuel setup. I believe I spent almost $600 myself. Here are some of the parts.. I know I’ll be missing some misc… After Market Fuel Rail Fuel Pressure Gauge Fuel Pressure Regulator Inline Fuel Filter Aftermarket Fuel Pump 20ft -6an Fuel Line 3/8” and 5/16” submersible fuel hose lots of AN fittings (I’ll explain all I used in the DIY steps) Hose clamps Zip Ties Attachment 455746 Attachment 455747 So lets get started…. The first thing you need to do is install your new fuel pump. I already have a DIY on installing a pump without a return. So start with this DIY to take out the pump and modify the cage https://honda-tech.com/forums/showth...=diy+fuel+pump Now lets start the new process! So I started my new fuel setup today. Basically I pulled the pump back out. I already had a 255lb pump installed. But now I'm adding a new feed and return setup. So first I dismantled the fuel pump assembly Attachment 455748 Then I went and place the nut on the bottom where I will be drilling. You will need this nut. You will also need a 90* male to male 6an fitting to go through the pump. Also I used a 6an to 3/8” barb fitting inside the pump. You can see the fittings in the picture above. Attachment 455749 Then I drilled out the hole. I used a blade to clean up the burrs and etc Attachment 455750 Now I placed my new fitting threw the hole Attachment 455751 Attachment 455752 Now I attach the barb connector and redo the hoses. I use the stock feed nipple as the return and connected the hose from the feed nipple to the return on the cage. Then route the pump to the new added barb fitting you drilled in. Attachment 455753 Attachment 455754 And put the pump back in the tank. Now to start the lines.... First thing I did was mount my inline fuel filter. First I wanted to wrap it in hose so it doesn't vibrate Attachment 455755 Attachment 455756 The using wire I mount it under the car where I wanted it Attachment 455757 Now start by putting your line from the pump. Here is the first straight -6an fitting used. Run the hose down to under the car to the fuel filter. Attachment 455758 |
Re: Fuel Return DIY
Posted it up and let me know and I will sticky it... if you decide to create a new thread let me know and I'll delete this one and sticky the new!
Good job bud!!! |
Re: Fuel Return DIY
9 Attachment(s)
and make a marking where to cut the hose to the fuel filter. Then make a cut
Attachment 455725 Now put your other end on Attachment 455726 and now put your first half of the fuel line up and tighten it down. You will need -10an to -6an adapters if you use the same aeromotive fuel filter. Attachment 455727 Then using the hose clamp I secured the hose down. Attachment 455728 I decided to stop using stainless braided hose and bought russells black braided hose. I started with the longest distance. So I began by adding a straight -6an fitting on the hose Attachment 455729 and then connected it to my FPR. If you want to put your FPR where I did here is my FPR bracket DIY https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/custom-bracket-fuel-pressure-regulator-2900020/ So anyways, connect another straight -6an fitting to the hose and start from the bottom of the FPR which is the return Attachment 455730 Then used clamps and started routing it down and around the header back over to the passenger side Attachment 455731 Attachment 455732 and wrapped it behind some of the wiring harness. I also zip tied the fuel line every chance I could just ass added protection Attachment 455733 |
Re: Fuel Return DIY
11 Attachment(s)
Then I cut the stock feed line back where you can't see it and zip tied the return line to it all the way down the frame...
Attachment 455714 Attachment 455715 Then put the hose through up to the pump and measured and cut where needed Attachment 455716 You also need to remove the quick release clip Attachment 455717 I then clamped it down to the stock feed output. It fit extremely tight and I could barely get it on so I have faith.... also this is the return so it has a lot less pressure. Attachment 455718 then I attached another AN fitting and started from where I had left off at the fuel filter Attachment 455719 I then brought it up towards the transmission and moved it up towards the rail. Attachment 455720 Attachment 455721 Now I put the rail on and fittings so I can mark where to cut the line. Now I make my mark on the hose and cut. Attachment 455722 Because this is going to be seen I don’t want to scratch the fittings. So I blue tapped them Attachment 455723 Attachment 455724 |
Re: Fuel Return DIY
7 Attachment(s)
Now I attach the line to the first side of the rail.
Attachment 455707 and now I attach the FPR fitting and measure up the next cut Attachment 455708 Attachment 455709 cut and add the fitting… almost done! Attachment 455710 attach the line Attachment 455711 BAM!!! Now you are done! Attachment 455712 here is a small diagram Attachment 455713 **I probably missed some things and I’ll edit the thread if needed** |
Re: Fuel Return DIY
Good write up!
Re: Fuel Return DIY
Nice write up !!
Re: Fuel Return DIY
Hey i had a shop do my return and it looks pretty similar. Im having a problem that the installer wont fix. Do you have any idea what would cause my car to sputter and lean out when im below 3/8 of a tank? it also seems like the pump is alot louder when low. if i have a full tank i dont have this issue. any idea what he did wrong? please help!
Re: Fuel Return DIY
1 Attachment(s)
Attachment 455231
This is where the return goes back into the cage. It helps get fuel to the pump even when low on gas. Check that |
Re: Fuel Return DIY
thanks ill take a look. maybe he didnt run it to the bottom and just let it dump in from the top. would that be the cause?
Re: Fuel Return DIY
Originally Posted by fg2k20z3
(Post 44945825)
thanks ill take a look. Maybe he didnt run it to the bottom and just let it dump in from the top. Would that be the cause?
HOWEVER!!!! The stock return is NOT large enough for higher fuel flow rates as the return fuel nozzle is literally only big enough to snugly fit a straw from an aerosol can (the little red ones that go in paint cans and stuff like WD40). All of the fuel that your fuel pump puts out (excempt what is used by the engine) must be returned to the tank through this tiny outlet. When you install a fuel pump that attempts to push more fuel than this tiny outlet can handle your fuel pressure spikes uncontrollably, corresponding with the amount of fuel requested by your engine. In other words your tune will be all over the place and the more fuel that your engine uses, the lower the fuel pressure will be. 2 Major problems with this. 1) Your injectors may break or fail to open under the increased pressure. 2) Your injectors require more voltage when your fuel pressure increases, thus leaving you in a sad situation if you find your battery a little low on startup. Even if you have enough power to crank your car you might not have enough to open your injectors. |
Re: Fuel Return DIY
This is spot on as this is exactly what I am experiencing with mine , fuel pressure starts off fine then under load it just goes and the car starts spluttering does this mean I need to get tuned???
Re: Fuel Return DIY
if you have an adjustable fuel pressure regulator yes you will need a tune for that.
Re: Fuel Return DIY
Nice write up 👍
Re: Fuel Return DIY
Really illustrative guide, thank you for taking the time to write and post it.
Not a job for the faint of heart perhaps, but good to see what is involved :thumbup: |
Re: Fuel Return DIY
Awesome...nicely done...nice products used...holy shit...
Re: Fuel Return DIY
(Post 44945221)
Re: Fuel Return DIY
Yea I have a problem on my rsx after I ran my return lines its starts to sputter then when i give it gas it shuts off.but the first time I installed it it was fine but the next day came and when i tried to start it up it started to studded and when I gave it gas the car shuts off ...and when i started it uo and looked at the fpr the psi was bellow 10 psi how come
Re: Fuel Return DIY
Widening the orifice worked for me. I ran smoothly regulated 60psi.
