Vtec sputter?
Old Nov 4, 2004 | 02:22 PM
type-r 01 886's Avatar
Default Vtec sputter?
Whats up guys, long time no post but ive been around, anyway.
Problem: I just noticed yesterday getting on the highway I was in 3rd and I always redline it when im getting on the highway in third but the other day at around 7500 rpms i notice a loss of power for a brief second. And then it proceded normal to 8500.
And I have been noticing tonight that now vtec engagues at around 6k sometimes and i lost power again but at like 7k rpms. Do you think its because my oil may be low? I am going in for an oilchange tomorrow, but I was wondering if anybody else ever ran into this problem.
I am right at the mileage for an oil change with 60,100 miles on the tach. 2001 ITR.
Thanks kids!
Old Nov 4, 2004 | 02:33 PM
Dan GSR's Avatar
Default Re: Vtec sputter? (type-r 01 886)
did you check the oil level
too little will prevent vtec from engaging
Old Nov 4, 2004 | 02:35 PM
TypeR15's Avatar
Default Re: Vtec sputter? (Dan GSR)
Oil
Old Nov 4, 2004 | 02:39 PM
Default Re: Vtec sputter? (TypeR15)
I hear different things from different people, do i check it when its cold or hot and where should it be on the stick? top hole or in the middle.
Old Nov 4, 2004 | 02:42 PM
TypeR15's Avatar
run the car...then let it settle...check the oil full is on the top hole...bottam hole is 1 quart less
Old Nov 4, 2004 | 03:07 PM
dsisive407's Avatar
From: around the corner to the left ... no, your other left
my best friend had a problem like that once on his 00 si. ended up being his vtec solenoid. vtec sort of sputtered every now and then .. dont know but it could be it.
Old Nov 4, 2004 | 04:57 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-r 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">I am right at the mileage for an oil change with 60,100 miles on the tach. 2001 ITR.Thanks kids!</TD></TR></TABLE>
first of all, 60000 miles is way to long without a oil change.
second of all, check the oil yourself. It will be at the top hole if its full, bottom if it needs oil, and the difference between the 2 holes is a quart.
Third vtec will sputter and most likely not engage when oil is too low.
Good luck, i Hope thats all thats wrong.
Old Nov 4, 2004 | 04:58 PM
mugenracer's Avatar
I cant believe you didnt even check your oil level first! It doesnt make much difference if the engine os hot or cold, so long as your parked on the level and the car has been switched off for a few minutes, so long as its between the two marks then your ok for oil and the problem is elsewhere. Fuel filter maybe???
Old Nov 8, 2004 | 07:05 PM
jdmLove4me's Avatar
i say check the oil type rs like to burn oil! then if it still does it check your spark plug wires, dist cap, or maybe even fuel pump line may be loose ( happend to me once), also try to unlugg your ecu for 15 min then plug it back in, OO ya u can also try using the fuel inj cleaner that goes into your gas tank! ONE more thing your vtec controller if u have one could be set to the WRONG throttle position...i dunno hope that helped...
baggedeg
Honda S2000
Jun 12, 2010 06:21 PM
green_beret
Sep 16, 2006 05:10 AM
GTI_guy
May 18, 2006 06:26 PM
01-1293
Oct 9, 2002 03:03 PM
ITR 0206
Aug 22, 2001 12:18 PM
