valve adjustment problem
Went to adjust my valves today, cyl1 and cyl2 went fine, but on cyl3, the exhaust side is way too tight, even with the adjustment screw loosened all the way, not even the .005 will fit
Any ideas? Already tried searching, didn't find anything relevent...
your probably not adjusting the valves in the right order...1-3-4-2....set tdc then go to the number 1 cylinder closest to the timing belt side...then turn it 90 degress counter clockwise then adjust cylinder 3...another 90 degress counter clockwise then cylinder 4 and so on...good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_meyer »</TD></TR><TR><TD CLASS="quote">. Incorrect?</TD></TR></TABLE>
YES ! That would mean your going 1,2,3,4
Again as mentioned the firing order is 1-3-4-2
STEVE MEYER I NEED TO TALK TO YOU ASAP! THIS IS CONCERNING ANDREW BOBKO THE GUY THAT RIPPED YOU OFF!! PLEASE EMAIL ME AT AH1406@WAYNE.EDU
