Torque sequence for the ITR head?
Old Jun 10, 2002 | 05:28 AM
1badITR's Avatar
Default Torque sequence for the ITR head?
I am changing the head gasket and I need to know the torque sequence for the ITR head. How should I remove and reinstall it? Thanks.
Old Jun 10, 2002 | 05:40 AM
kenji's Avatar
25 Year Member
Default Re: Torque sequence for the ITR head? (1badITR)
The follwing numbers represent head bolts when viewed from above. The bottom numbers represent the head bolts closest to the front bumper. This is the tightening sequence that should be followed.
9 5 1 3 7
8 4 2 6 10
-kenji
Old Jun 10, 2002 | 06:58 AM
Dave-ROR's Avatar
I have a feeling the tq seq will be the least of your problems.. perhaps you might take it to a shop that deals with building honda motors?
-Dave, who is not trying to be offensive but...
Old Jun 10, 2002 | 07:09 AM
JPP's Avatar
JPP
If I read between the lines of your question, you don't have an Helm manual and you want somebody on this board to tell you the steps on removing and reinstalling the head ? That is not the way to do things if you want a job well done.
The first thing you should, if you want to do the job yourself, is buy the Helm manual. Then you will have all the information you need to do the job. It is not as easy as removing 8 bolts in the right sequence.
Old Jun 10, 2002 | 07:17 AM
Dave-ROR's Avatar
Default Re: Torque sequence for the ITR head? (JPP)
Especially since there's 10 bolts!
Old Jun 10, 2002 | 07:32 AM
JPP's Avatar
JPP
Default Re: Torque sequence for the ITR head? (01_Yeller_ITR)
8 bolts, 10 bolts....details, details. Once you have the right sequence for the first 8 bolts the last 2 are easy
Old Jun 10, 2002 | 07:53 AM
Mike K's Avatar
I do it differently, but I guess everyone has different approaches on things.
7 3 1 5 9
8 4 2 6 10
remember, 63 ft/lb.
also, be sure to torque the cam rail bolts to 20 ft/lbs. also, using the same torque method as mentioned above. those are the 12mm ones. the 10mm ones, just tighten them as tight as you would do the valve cover nuts. 20 ft/lbs. on those, and you'll be using an extractor to remove the threads from the head. LOL.
Donhonda84
Jun 20, 2007 04:57 AM
AZTech
Jan 24, 2007 03:04 PM
roger93si
Jan 16, 2007 10:12 AM
roger93si
Jan 16, 2007 02:14 AM
