Things to change/replace while the head is removed?
Old Jan 30, 2002 | 10:13 AM
Austin's Avatar
Default Things to change/replace while the head is removed?
Sometime in the near future Chris and I will be pulling the head, what do I need to replace, and what should I replace/change since the head will be removed?
And yes I'm going to be replacing the headgasket
Thank you for your time,
Austin
Old Jan 30, 2002 | 10:16 AM
sgT's Avatar
sgT
Default Re: Things to change/replace while the head is removed? (Austin)
head gasket
head bolts
cam seals
valve cover gaskets
Old Jan 30, 2002 | 10:25 AM
D's Avatar
D
Default Re: Things to change/replace while the head is removed? (sgT)
Valve cover gasket... wow, overkill?
sgt, just curious if you ever re-use your head bolts
D
Old Jan 30, 2002 | 10:33 AM
Austin's Avatar
Default Re: Things to change/replace while the head is removed? (D)
D
Big valve cover gasket $9.00...if it's off change it, it's very easy to do.
Old Jan 30, 2002 | 10:37 AM
D's Avatar
D
me = lazy poor college student. if i replaced the valve cover gasket every time i had it off, i'd have zero money for $1 's
D
plus, they hold up for quite a long time. hondabond is your friend.
[Modified by D, 2:37 PM 1/30/2002]
Old Jan 30, 2002 | 10:39 AM
HX_Guy's Avatar
Yea I reuse the valve cover gasket all the time..never hard any problems.
I have also re-used head bolts..but its probably better to just get new ones...it would be a pain to ahv to redo it all over again if they stretch.
Old Jan 30, 2002 | 10:52 AM
Cheap Bastard's Avatar
New User
High compression pistons.
Old Jan 30, 2002 | 11:36 AM
sgT's Avatar
sgT
I will reuse headbolts ONLY if i have no new ones around and I NEED to get the
car running(ie a race is that day). and i'll never reuse more than once.
Reason why i replace the valve cover gasket is because I have had them
split on me after removing the cover a few times. Sucks when oil gets spit out
all over the engine bay.
must be all that crankcase pressure.....
Old Jan 30, 2002 | 12:49 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
How many head bolts are there? 10?
Old Jan 30, 2002 | 12:50 PM
sgT's Avatar
sgT
Default Re: Things to change/replace while the head is removed? (RealTypeR)
yes
Old Jan 30, 2002 | 01:14 PM
D's Avatar
D
woulda thought you had ARP studs in there already....
tks for response.
D
Old Jan 30, 2002 | 01:16 PM
sgT's Avatar
sgT
i did. then the head gasket started leaking.
changed the head gasket 3 times until i decided it was the studs.
went to stock bolts and problem solved
Screw arp
Old Jan 30, 2002 | 01:26 PM
D's Avatar
D
Screw arp
alright then. good info.
D
Old Jan 31, 2002 | 06:57 AM
ZygSpeed's Avatar
....changed the head gasket 3 times until i decided it was the studs.
How about ARP when used with a thicked head gasket, and turbo?
Old Jan 31, 2002 | 09:01 AM
sgT's Avatar
sgT
Default Re: Things to change/replace while the head is removed? (zygspeed)
I myself am a firm believer of stock head bolts.
I have seen the head lift with both arp and stock bolts under boost so........
Old Jan 31, 2002 | 10:11 AM
JPP's Avatar
JPP
Is there a particular reason that you do not reuse head bolt?. If the bolts give you proper clamping force, does it matter if they are used or not? I would be more worried about somebody overtightening them and damaging the threads in the block. Just curious here.
Thanks
Old Jan 31, 2002 | 10:15 AM
sgT's Avatar
sgT
Default Re: Things to change/replace while the head is removed? (JPP)
they stretch
Old Jan 31, 2002 | 10:17 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
they stretch
I still wouldn't be that concerned.. and like Steve said, I've also see ARP studs lift. Albeit on a Conquest.. but still, they aint all that.
98GSRDC2
Mar 5, 2007 10:13 AM
Bone Stock
23
Sep 26, 2004 06:03 PM
bigmike
Apr 10, 2003 11:13 PM
Hans
Mar 11, 2003 06:19 AM
Rhetoric
Jul 15, 2002 01:58 PM
