Skunk2 Cams
Subscribe
Jun 26, 2001 | 08:47 PM
Hi..Why do you guys say skunk2 cams are garbage when a yellow integra type R that runs for them is hitting 12s all motor wit the sets of cams they sell?plmk..thanks...cause i am very interested on getting them..and would like to know whats wrong wit them..thanks
Reply 0
Jun 27, 2001 | 07:24 AM
Re: Skunk2 Cams (JDMRACER95)
They had a problem with the first batch many many months ago. The coating that the factory applied was a race coating which was too hard. The replaced the bad cams under warranty and the problem is fixed. The skunk2 cams are stronger then the ctr cams, the price is good too. I have a customer that has a gsr with jdm itr pistons, skunk2 manifold, field vtec controller, AEM cold air, comptech header, greddy exhaust and he's dynoed skunk2 cams and cam gears and he's dynoed at 186hp at the wheels......that's 40 more hp more then a stock gsr,,,,,,so, yes, they work
And no problems since the new batch has been released over 6 months ago
[Modified by TypeRdude, 4:24 PM 6/27/2001]
[Modified by TypeRdude, 4:25 PM 6/27/2001]
Reply 0
Jun 27, 2001 | 07:30 AM
Re: Skunk2 Cams (TypeRdude)
Actually, that is not entirely accurate....
They went looking for a coating to make the cam compatable with the rockers, which the cams were eating in 10k miles. Not such a good thing.
They had several hundred pairs of these cams, and the billets that were used were harder than the rockers; thus the incompatability.
The bad bunch of cams were scrapped, a new billet was introduced, and there is no more problem.
As mentioned, they are making some good power, however, it is only the VTEC lobes that have been beefed up, not the primaries.
Reply 0
Jun 27, 2001 | 07:46 AM
Re: Skunk2 Cams (2fcknfst)
By what I've heard, the Skunk2 cams are similar to the ITR/CTR cams on the primary lobes, and slightly bigger than the Toda A spec cams on the VTEC lobes.
I want to try a set to see how they compare, but I'm happy with my Spec A's.
Reply 0
Jun 27, 2001 | 08:39 AM
Re: Skunk2 Cams (Mike K)
We have posted Dave Hsu's email to me on our website (no snide remarks from the peanut gallery please) at Superhonda regarding this. Here is their side of the story.
Quote:
tuan-
thank you for your e-mail. i appreciate your effort in keeping the
information on your site accurate.
in march of 2000, we issued a re-call for our initial shipment of camshafts.
we contacted all customer and dealers and informed them that they might
experience premature wear with some of the cams due to inconsistencies in the pvd coating. we took care of all customers experiencing this problem by replacing the cams and/or rockers as well as compensating them for
additional labor charges.
we have since changed manufacturing processes and have had no reports of pre-mature wear. we are utilizing the same technologies used by japanese auto manufaturer. our core supplier is an oem for both honda and nissan vehicles. with this new supply of cores, you can expect to see camshafts for many other models of cars. for the record we have never had any breakages with the cams old or new.
group-a autosports stands behind the products it sells above and beyond
industry standards and our competitors. ...
here are the specs you asked for on these cams:
int .456" (11.58mm), 252 @ 1mm / exh .429" (10.9 mm), 249@1mm
these cams pass smog and do not require the use of new valvesprings (though recommended). b18c1 engine makes 17+ more to the tire on avg.
please inform your readers that bigger is not necessarily better. we have
only seen 2-4hp increases when using toda B's or jun3's. neither pass smog. both require new valve train. and in the case of jun's there is only a 3-4 degree margin of error before the valves grab each other and destroy the motor. with the current cam our goal was to make as much power using stock valvetrain, while preserving driveability, reliability, and emission friendliness.
best regards,
dave
skunk2
As you can plainly see these are not ITR or CTR cam specs which are
ITR IN 0.453 " (11.5 mm), 240 @1mm/EX 0.413" (10.5 mm), 235 @ 1mm
CTR IN 0.453" (11.5mm), 243 @ 1mm/EX 0.413" (10.5 mm), 235 @ 1mm
Hope this clears things up.
cheers
Reply 0
Jun 27, 2001 | 08:44 AM
Re: Skunk2 Cams (Michael Delaney)
Good info.
Reply 0
Jun 27, 2001 | 08:46 AM
A guy in a Gen 2 teg with a B16A motor swap equipped with Skunk2 cams and cam gears, intake, header, exhaust and every other possible bolt-ons you can imagine raced me a couple weeks back. I was in my R with just an AEM intake. The car has just barely been broken in and it was my first time ever drag racing. I beat him by half a car length. Not an actual prediction of what might happen if it was installed in an ITR but the B16A is almost the equivalent of an ITR motor...
My advice...try them for yourself
[Modified by ILOVERACING, 12:47 PM 6/27/2001]
Reply 0
Re: Skunk2 Cams (B18CXr)
Quote:
Good info.
Wrong info from Skunk d00d.
"we have only seen 2-4hp increases when using toda B's or jun3's."
I am glad to hear what the cause was and the steps taken to fix it. The camshaft info from Mr. D is also very helpful.
Will
Reply 0
Jun 27, 2001 | 08:51 AM
Re: Skunk2 Cams (ILOVERACING)
um, b16a = 160hp (flywheel). b18c5 = 195hp (flywheel). the heads are very similar, but the larger displacement and slightly higher compression (not mention more aggressive cams) help the b18c5 out a lot.
not trying to be a pain, but my last car had a b16a in it, and after what i was planning to do to it engine-wise, i would basically end up with the stock power of a b18c5. so, i traded up to the R.
Reply 0
Jun 27, 2001 | 10:27 AM
Re: Skunk2 Cams (Willard)
The comment that Todas only made 2-4 whp more than the skunks is not entirely implausible:
stock ITR 160-163 whp on avg.
skunk2 gains 15-17 whp. 175-180 whp. no change in compression.
if you see Lip's dyno when he had Toda B's, JDM 4-1, stock compression, he made around 180-185 whp.
Reply 0
Jun 27, 2001 | 10:42 AM
to say the skunks made +17hp average is a flat out lie, pure and simple..........
B's make around +12-15 ish peak hp over the OEM cams (assuming all other mods are kept the same) so that's almost in line, but the B's add+20 HP and 15-20 ish LBS. on low cam!!
JunIII's may do the same but I've yet to see a plot.....skunks will give "almost spec B" top end but, I like my low lobes lumpy for smooth,across the board gains and the skunks WILL NOT DO THAT!
Nice discussion, Let's keep it that way
[Modified by B18CXr, 2:43 PM 6/27/2001]
[Modified by B18CXr, 2:56 PM 6/27/2001]
Reply 0
Jun 27, 2001 | 10:56 AM
this was last year with the jdm 4-1 with badly leaky rings using spec B's. i obviously opt to keep run 63 given the torque increased throughout the power band with only a hp or 2 loss
Reply 0
Jun 27, 2001 | 11:08 AM
Good info guys..thanks..i think imma go with those setup cams for my jdm itr motor.....thanks guys...
Reply 0
Jun 27, 2001 | 11:22 AM
Re: Skunk2 Cams (JDMITR02)
I am just looking for a set of cams to help me on my quests to 12s so far i see the skunk2 cams able to do it..i seen toda Cs but i want something that is daily driven and not that wild of a cam..
Reply 0
Jun 27, 2001 | 12:44 PM
Jack,
Dave Hsu did say 17 hp in a B18C1. What it does in the B18C5, I'm not sure. I'm extrapolating what Dave said to the ITR. So if the gains were similar, the numbers would come close to what he stated...plausible. ITRs with thinner 0.6mm single layer head gaskets have shown gains to 190 whp...not a major change in CR but still not stock..."close" to stock...10.9:1. I guess what I was saying is, if we compare these cams we should make sure the engine combinations are similar.
Jeff,
this is the plot I was referring to:
[Modified by Michael Delaney, 1:49 PM 6/27/2001]
Reply 0
Jun 27, 2001 | 12:48 PM
Re: Skunk2 Cams (Lip)
What compression were you running here Jeff when you made 192 WHP?
You ran a 13.1 quarter with this right?
Reply 0
Jun 27, 2001 | 01:28 PM
here's another spec B plot on a 2000 Type R with 11:1 compression ... incredible torque, I've never seen that from the skunks or the JUNs
Greg
Reply 0
Jun 28, 2001 | 04:46 AM
Thats my RS*R header plot. The one i posted was the jdm 4-1. the RS*R couldn't flow the b's. only differences between the plot i posted and the one you did was change of header and added an msd(which didn't do much for me at that point).
Reply 0
Re: Skunk2 Cams (VTEC-MAN95GSR)
about 11.1-11.3:1 with the 192whp
Reply 0
Jun 28, 2001 | 09:24 AM
Ohh cool. The reason I ask is cuz I wanna estimate where my WHP should be using your former set-up as a baseline. since I got the Toda B's, 11.8 compression, Spoon 4-1 header with a straight pipe, I'm hoping for 200+ WHP or bust.
BTW, will the 13" Lenso VPD's go over my stock GSR calipers?
Reply 0
Jun 28, 2001 | 09:28 AM
yupper sure will. and you'll hit 200 btw
Reply 0
Jun 28, 2001 | 09:37 AM
i also wanna do the fastbrakes type-R front kit upgrade in the future, do you know if those 13" Lensos will still fit?
Thanks for the 200+ reassurance, I feel a lot better....
Reply 0
Jun 28, 2001 | 09:40 AM
nope, the wheels will not clear the brakes......
Reply 0
Jun 28, 2001 | 09:49 AM
shoot!
Reply 0
Jun 28, 2001 | 10:26 AM
Quote:
Jack,
err, no, not plausible. You cannot compare the B18c's gains to what a ITR would gain. The ITR cams are much more aggressive than the GSR's, therefor the gains would not be as high. I'd say on the ITR the gains would be more along the range of 10hp.
Reply 0
