question for engine builders!!
Old Jun 30, 2002 | 06:59 AM
No-Gi's Avatar
Default question for engine builders!!
Okay, 1 piston needs to be replaced in my b16.
The block has been bored 81.5 mm so my concern is can it be honed again.
I will be replacing the piston and ring for cylinder #4. I am concerned that once i hone the cylinders, since its been bored over that It will be too big and burn oil.
Should i just buy a bare block and do it all over again?
Old Jun 30, 2002 | 07:08 AM
DonF's Avatar
Default Re: question for engine builders!! (B16aEK)
It really depends on damage to the cylinder, out of round, or deep scratches. If the cylinder just need a light hone,to de-glaze , you are ok, but if not just have that cyl. re-sleeved,approx. $80.-85.00.
Old Jun 30, 2002 | 07:10 AM
2k1_ITR_0736's Avatar
or get it bored and sleved by darton international, and put 20 psi on it.
Old Jun 30, 2002 | 07:28 AM
No-Gi's Avatar
Default Re: question for engine builders!! (2k1_itr_0736)
I guess it depended on the damage. All the hone marks are there. The engine only had 4000 miles on the rebuild.
It does have some vertical scratches on the cylinder wall but not too deep. No boost for me. Been there, ran 12's.
Old Jun 30, 2002 | 07:37 AM
DonF's Avatar
Take it back to the shop that machined it and have them run a Dial-bore guage in it. How did you lose the piston ? Detononation ?
Old Jun 30, 2002 | 08:03 AM
No-Gi's Avatar
Default Re: question for engine builders!! (DonF)
Big cams, no clearance. Valve broke and put 2 holes on the piston
Old Jun 30, 2002 | 08:19 AM
DonF's Avatar
If the parts didn't bounce around and scar the walls you might be OK, Curiously,what aftermarket pistons didn't have enough clerance, most I have seen have too much, or just big cams with the lobe centers to close?
Old Jun 30, 2002 | 08:21 AM
No-Gi's Avatar
wiseco 12:1 pistons. it might have been a bad cam install.
Buffs8080
Honda Civic (2001 - 2005)
Jan 20, 2014 06:52 AM
JohnnyEF
May 29, 2003 12:38 PM
Brian_92GSR
Aug 3, 2002 09:05 PM
