LSD additive
Old Jun 7, 2008 | 11:17 AM
garyc17's Avatar
Default LSD additive
Anyone tried Amsoil Slip-Lock differential additive for their clutch type LSD tranny? Does it really do what it claims?
Info can be found here: https://www.amsoil.com/storefront/ada.aspx
Modified by garyc17 at 1:32 AM 6/8/2008
Old Jun 7, 2008 | 05:46 PM
vinuneuro's Avatar
Default Re: LSD additive (garyc17)
What you want for a clutch-type lsd is redline mtl and ford friction modifier. Proven to work well with those type of lsd's.
Old Jun 7, 2008 | 07:26 PM
garyc17's Avatar
Which would that be based on this link:
http://www.fordracingparts.com...tials
Old Jun 7, 2008 | 07:31 PM
vinuneuro's Avatar
Default Re: (garyc17)
I think they're both the same, but different quantities. I think the first one is 4oz? Put a bottle's worth with the Redline MTL.
Modified by vinuneuro at 10:37 PM 6/7/2008
Old Jun 7, 2008 | 11:37 PM
jjesus's Avatar
torco is what i use that stuff is the way to go nver had any problems after 4yrs with same tranny
Old Jun 8, 2008 | 12:35 AM
garyc17's Avatar
I was thinking of trying AMSOIL - Slip-Lockâ„¢ Differential Additive (ADA). It seems more popular with rear diffs in 4X4s.
Old Jun 8, 2008 | 04:41 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone tried Amsoil Slip-Lock differential additive for their clutch type LSD tranny? </TD></TR></TABLE>
I'm a tiny bit worried. You're using a Kaaz unit, or what?
Old Jun 9, 2008 | 02:35 AM
garyc17's Avatar
Default Re: LSD additive (George Knighton)
Its a spoon 1.5way clutch type LSD. I'm going to put the Amsoil Slip Lock now. Fingers Crossed.
Old Jun 9, 2008 | 08:22 AM
garyc17's Avatar
VIOLA! This fluid solved the problem totally! No more stuttering, clunking or noise. Emptied half the bottle (~2oz.) of it into my tranny. It shuddered on the first 2 or 3 extreme turns and then no more. Very satisfied with the outcome. I'm sure GM friction modifier or redline modifier works just as well, but for now Amsoil Slip Lock is the honey for my tranny.
Old Jun 9, 2008 | 07:46 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">VIOLA! This fluid solved the problem totally! No more stuttering, clunking or noise. Emptied half the bottle (~2oz.) of it into my tranny. It shuddered on the first 2 or 3 extreme turns and then no more. Very satisfied with the outcome. I'm sure GM friction modifier or redline modifier works just as well, but for now Amsoil Slip Lock is the honey for my tranny.</TD></TR></TABLE>
Looks like we have another solution for those with clutch pack LSDs.
Did you mix it with Honda MTL or what tranny fluid did you use? I can't recall how much I purchased the Ford Friction modifier for back in the day because I bought it in a case of 12. But at $7.45 for the Amsoil stuff, it doesn't seem too pricey.
Old Jun 10, 2008 | 03:21 AM
garyc17's Avatar
I'm quite sure this works with just about any MTL or tranny fluid. I am on Motul 75W140 which is some serious thick stuff. I would go for something thin for the B-series gearbox since that is the recommendation from Honda. Initially I was having problems and wanted to see if the 75W140 would work out. It seems the friction modifier was the answer.
Craigp23usa
Aug 21, 2006 05:24 AM
Baron55
Aug 6, 2006 01:53 PM
charjacq
14
Dec 10, 2002 07:57 PM
meams
Jul 14, 2002 07:37 AM
