Lowering the compression on B18C5
Old Dec 19, 2007 | 06:51 AM
HarfordCTR's Avatar
Default Lowering the compression on B18C5
I have all my turbo parts ready to go on my Type-R. I am planning on running the stock internals for a year at most. Untill I can get a GSR block and build that. What are you guys doing about lowering your compression other than Pistons and rods? I hear people use the thick headgasket. Which one is the most reputable? GE, Cometic, etc. And how thick would be good for a nice street setup? Maybe like 10 lbs of boost on a T3T04E 57 trim. Would like to get 300 whp, give or take a few. Thanks in advance.
Old Dec 19, 2007 | 07:39 AM
JjuuN R's Avatar
Then just leave the compression alone if your plans are 10lbs/300whp.
Old Dec 19, 2007 | 07:43 AM
KaBlookie's Avatar
Default Re: (JjuuN R)
The idea that lowering compression is necessary for turbo builds like yours is outdated and incorrect. All it does is allow whoever is tuning the car a greater margin for error while tuning, in which case you ideally shouldn't be going there in the first place.
Leave your compression as it is and get it tuned by somebody who really knows what they're doing, and you'll be good to go.
Old Dec 19, 2007 | 07:45 AM
migs's Avatar
I used an HKS headgasket which lowered it to 8.6:1 compression. By lowering compression, you are just decreasing your peak WHP and increasing your longevity. However, with the tuners available today and software, you can still have a reliable setup using stock compression and dyno'ing over 300whp.
Old Dec 19, 2007 | 07:53 AM
HarfordCTR's Avatar
Default Re: Lowering the compression on B18C5 (HarfordCTR)
It's a new h/g in there now. So Im just gonna leave it alone. Any suggestions for a good tuner in MD/PA area. I've dealt with JE and I don't really want to go there But I've heard Tempest Racing would be a good choice. Anyone? Thanks for the help
Old Dec 19, 2007 | 07:54 AM
RNbuilt's Avatar
its all about the tune...
Erik95LS's Avatar
The best possible way to accomplish this is by signing up for Expo
Old Dec 19, 2007 | 08:01 AM
HarfordCTR's Avatar
Default Re: Lowering the compression on B18C5 (Erik95LS)
Looking for a reputable tuner in my area
Old Dec 19, 2007 | 08:26 AM
cmdr430's Avatar
What ems are you using or going to be using?
Old Dec 19, 2007 | 09:41 AM
HarfordCTR's Avatar
Default Re: Lowering the compression on B18C5 (cmdr430)
Hondata S300
Old Dec 19, 2007 | 09:47 AM
CRJenkins13's Avatar
Stock head gaskets are already 3 layer, so going with Cometic really doesn't drop it much.
Just figured I'd beat the point to death a little more.
Old Dec 19, 2007 | 10:19 AM
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">The best possible way to accomplish this is by signing up for Expo </TD></TR></TABLE>
nice
Old Dec 19, 2007 | 10:52 AM
Henryx33's Avatar
Like everyone else had said, get a good tuner. I've been running on stock internals for a long time
Modified by Henryx33 at 7:51 PM 12/19/2007
Old Dec 19, 2007 | 11:19 AM
neo_'s Avatar
Old Dec 19, 2007 | 12:16 PM
HarfordCTR's Avatar
Default Re: Lowering the compression on B18C5 (neo_)
^^^^^ WTF is that???????
Old Dec 19, 2007 | 12:42 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">I used an HKS headgasket which lowered it to 8.6:1 compression.</TD></TR></TABLE>
A headgasket lowered your compression a point and a half? how many fingers thick was it? lol. or did i just not understand that and there was other things done to the internals and the HKS HG was the final piece that got it to 8.6:1?
Also, Evans Tuning is in PA, well worth it.
Old Dec 19, 2007 | 01:40 PM
MattyP's Avatar
Default Re: (ComeOnKip)
Shew...I remember when Brian Arborgast Ran low 10's on a STOCK ITR, made 550ish WHP...trying to blow it up and couldnt...But ofcourse, he was a great tuner
Old Dec 19, 2007 | 02:37 PM
00-501itrspec's Avatar
Jeff Evans is in PA and has a great reputation .
Old Dec 19, 2007 | 03:17 PM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">
Also, Evans Tuning is in PA, well worth it. </TD></TR></TABLE>
Yes, 1.5pt. The headgasket was pretty thick. If memory serves but dont quote me on this, it was 3mm. It is now discontinued but yes, compression was 8.6:1 with just a headgasket alone.
Old Dec 19, 2007 | 03:28 PM
RRRRRRRR's Avatar
&lt;--- thinking about dropping the JRSC and move up to the TURBLo....
Old Dec 19, 2007 | 03:33 PM
Default Re: (RRRRRRRR)
^^^^^DEW EET
Old Dec 20, 2007 | 12:32 PM
HarfordCTR's Avatar
Default Re: (white rocket)
I heard Jeff Evans is the ****. Anyone know where in PA he is located? Thats a big state
Old Dec 20, 2007 | 02:56 PM
Boosted_01 R's Avatar
Default Re: (HarfordCTR)
Jeff is amazing, has a lot of experience.
For 300WHP don't change a thing. Its a waste of money. Plus is you change the head gasket your gonna need cam gears too (thicker gasket changes valve geometry).
As long as you have a good tuner you'll be fine
Old Dec 21, 2007 | 04:33 AM
HarfordCTR's Avatar
Default Re: (Boosted_01 R)
I have cam gears already
Old Dec 21, 2007 | 04:46 AM
MiraiZ's Avatar
The head gasket will be the weak point in your setup. Do it right and get some forged pistons and rods.
