Intake Insulation
Old Sep 16, 2001 | 04:38 PM
Tommy_Gunns's Avatar
Default Intake Insulation
What do people use to insulate your aftermarket intake? My aftermarket intake tube gets extremely hot and I would like to insulate it from the engine.
Thanks.
Old Sep 16, 2001 | 05:10 PM
Sa-Da-Teh's Avatar
New User
Default Re: Intake Insulation (Tommy_Gunns)
Home Depot has a wide selection of sheet metal and brackets you can use to modify a box to cover the intake. It cost me $0.34.
Old Sep 16, 2001 | 05:23 PM
Default Re: Intake Insulation (ITR-01-0871)
I was talking about the intake tubing...I want to insulate that and was wondering what people are using.
Old Sep 16, 2001 | 06:05 PM
EleanoR's Avatar
Well i am getting ready to wrap my AEM tube in header wrap. I dont know if it will help or not but we will see
Mike
Old Sep 17, 2001 | 10:46 AM
Striker's Avatar
New User
You could try having it powder coated. That should help w/ the heat.
Old Sep 17, 2001 | 11:14 AM
Austin's Avatar
Thermo-Tec wrapping...available at most performance shops...Jegs, Summit...
Old Sep 17, 2001 | 11:41 AM
Kengs's Avatar
Default Re: Intake Insulation (Austin)
Billion makes some really nice thermo wrap/sheets.
Old Sep 17, 2001 | 11:51 AM
FAST94GSR's Avatar
New User
Default Re: Intake Insulation (kengs)
Try header wrap OR I bought this insulation kit from Summit for intakes. Its a aluminum style wrap. It goes on easy and reflects heat. I think I paid like 40 bucks for it. I'm not using it so if you wanna buy it from me i'll sell it to you cause I'm **** poor broke right now.
Old Sep 17, 2001 | 07:45 PM
Chris's Avatar
Do this, Scroll to the bottom:
I made some heat shields..and thet will work with ANY intake configuration.
http://home.pacbell.net/justha3
Old Sep 17, 2001 | 10:20 PM
Bob#455's Avatar
Default Re: Intake Insulation (Chris)
Wow, that's a nice heat shield! Where could I get one of those?
Old Sep 18, 2001 | 12:01 AM
ThePunk's Avatar
Default Re: Intake Insulation (Bob#497)
Here's a wrapped AEM....
Notice the wire running into the rubber coupling in the last picture?
That is a thermocouple temperature sensor. I measured the air temps around town and on the highway before and after wrapping at the throttle body. I noticed a difference of up to 15 degrees!
[Modified by ThePunk, 1:03 AM 9/18/2001]
Old Sep 18, 2001 | 07:15 AM
Dropspeed's Avatar
Default Re: Intake Insulation (ThePunk)
What about heat soak after the vehicle is shut off. The header wrap was designed to keep heat in. If it does warm up does it take longer for it to cool off?
Mattj
Old Sep 18, 2001 | 11:13 AM
ThePunk's Avatar
Default Re: Intake Insulation (Dropspeed)
The nature of the wrap material blocks heat. Therefore I doubt it would let heat "soak through" in substantial amounts. Even so, upon turning on the car again, the lightly warmed air inside the intake would be consumed rapidly, allowing cooler air to replace it.
7rrivera7
13
Oct 25, 2007 11:12 AM
DCxMagus
Sep 11, 2007 09:37 PM
brnyrdcmndo
11
Jan 27, 2006 04:48 PM
civiccoupe94
Jul 19, 2005 11:27 AM
sikcrx80
Jul 9, 2003 08:03 PM
