Deisel compression gauge..
Old Apr 10, 2003 | 01:00 PM
Nameless RB26's Avatar
Default Deisel compression gauge..
I'm a little obsessed with this compression stuff right now, sorry..
My compression seemed to go over my gauge, like I said in another thread yesterday (255+)
Can I use a deisel compression gauge that reaches 800 psi? I know some of you guys get over 255.. what gauge are you using? I want one that reaches atleast 300.. but I do not see one in the snap-on catalog that goes over 255.
This probably isn't ITR related, but I'm testing my R engine.. and I know some of you have high numbers.
EDIT: 255.. not 155
Old Apr 10, 2003 | 01:12 PM
PyR01-0347's Avatar
Default Re: Deisel compression gauge.. (Nameless EJ6)
I don't think you can use a diesel compression gauge becuase all the compression gauges I have seen for gasoline engines uses the spark plug hole to measure the compression. With a deisel motor there is no Spark plug(some do have Glow plugs). Diesel motors use super high compression to create the nessary heat to ignite the air/fuel mixture. I don't think the diesel gauge will work for our gas powered motors. Also it doesn't matter about how high the compression numbers are. Aslong as the numbers are consistant with all the cyclinders you should be fine.
Old Apr 10, 2003 | 01:35 PM
Default Re: Deisel compression gauge.. (PyR01-0347)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyR01-0347 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can use a diesel compression gauge becuase all the compression gauges I have seen for gasoline engines uses the spark plug hole to measure the compression. With a deisel motor there is no Spark plug(some do have Glow plugs). Diesel motors use super high compression to create the nessary heat to ignite the air/fuel mixture. I don't think the diesel gauge will work for our gas powered motors. Also it doesn't matter about how high the compression numbers are. Aslong as the numbers are consistant with all the cyclinders you should be fine.</TD></TR></TABLE>
Yes, I know. But I cannot judge consistency if I can't see where it's going. I don't care about high numbers...
But the compression gauge for deisel is just a gauge, I couldn't use the adaptors. The snap-on one I'm looking at has the standard connection on the end (I forget the name of this).. so it should work on my spark plug adaptors I'm thinking..
Old Apr 10, 2003 | 01:52 PM
Big Phat R's Avatar
Get one from Longacre racing products.
Goes up to 300 psi
http://www.racerpartswholesale.com/long29.htm
Old Apr 10, 2003 | 01:53 PM
sneakychaos's Avatar
Default Re: Deisel compression gauge.. (Big Phat R)
..i picked one up from pep-boys for like 10$... goes to 300psi.
Andy1234
Apr 5, 2018 07:19 PM
sanjoseDA9viet
Dec 16, 2006 03:34 PM
sanjoseDA9viet
Northern California (Sales)
Dec 12, 2006 01:47 PM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
