Check Engine Light Code 67, AGAIN, Need Help!
Old Apr 14, 2002 | 12:18 PM
onyx00's Avatar
Default Check Engine Light Code 67, AGAIN, Need Help!
Okay, before I had a Carsound cat. the element came loose I threw a code 67, replaced the cat about two months ago all was fine.
This time driving in 90+ degree weather, and no rattling or anytihng wierd the MIL lights up, I check it, code 67 again!
I gave a quick look under the car, all looked well. The cat. is a brand new Carsound cat. I reset the ECU and am going for a drive now to test to see if it will come back on.
Any suggestions on troubleshooting procedure? Any ideas other than the cat. may be bad again??
Please help me
Old Apr 14, 2002 | 12:29 PM
stRtypR25's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (onyx00)
i had the same prob. i am almost 100% sure that it is your rear o2 sensor
Old Apr 14, 2002 | 12:38 PM
hooptie157's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (stRtypR25)
rear 02 sensor, man that sux it cost 225.00 from the dealership, trust me I know cause I had the same problem
Old Apr 14, 2002 | 01:08 PM
sgT's Avatar
sgT
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (hooptie157)
i doubt its the o2 sensor, more than likely its just the cat doesnt do as good of a job as the stock one.
Old Apr 14, 2002 | 01:11 PM
StinkyTofu's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (sgT)
I get the same code, theres nothing wrong. Your ecu doesn't like your mod.
Old Apr 14, 2002 | 03:14 PM
onyx00's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (StinkyTofu)
But it liked the mod for a whole year unitl the old cat. died and the element went loose.
I just find it out that all of a sudden the ECU wouldn't like the cat.
Will this affect performance at all?
Old Apr 14, 2002 | 04:19 PM
gsr98vtec's Avatar
switch to obd-1 and all your problems will disappear.
Old Apr 14, 2002 | 05:02 PM
Willard's Avatar
3-#67 CEL's and a very high sniff #'s = Will
I replaced my air filter/rotor/cap and the car "smells" better.... i need to see what the sniff #'s are to make sure that the modifications are what made the difference.
Will
Old Apr 14, 2002 | 06:05 PM
Eeepers's Avatar
New User
I have the same problem. First of all, did you check for any exhaust leaks after the header? Is your air/fuel ratio okay? Running excessively rich can damage the cat.
If everything is okay, then you can either use an O2 simulator, or convert to OBD1.
I've seen them advertised for as low as $25.
The O2 simulator just tells the ECU that your cat is functioning properly so you won't get CEL 67.
Old Apr 14, 2002 | 06:22 PM
sackdz's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (Eeepers)
My OBD II godspeed testpipe is working fine after a year
sackdz-who has a stinky exit hole
Old Apr 14, 2002 | 06:47 PM
EJK's Avatar
EJK
New User
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (sackdz)
I had the same problem.. Installed a Car Sound cat arounf June of last year and 6 months later, threw a code 67... The weirdest thing is that I'll have that MIL on for like 3 weeks then just dissapear on any given day, until it come back again around 2 -3 days later. It comes on intermittently and the days I have ithe MIL on varies from like 3 weeks to months until it clears again... checked under the car and everything seems to be ok...don't really have to deal with that problem anymore when I went OBD1.
Old Apr 14, 2002 | 11:41 PM
t's Avatar
t
, Its the cat converter chances are the material is melted again.
Old Apr 15, 2002 | 07:17 AM
itr--779's Avatar
New User
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (t)
yep i've had this problem too and it seems to be acting up again!
got code 67 last week.
Nothing physically wrong with the cat but my R is running rich and i can't
figure out why. Its not pressure its pulse width.
Very frustrating.
You getting any other symptoms?
black plugs, black around exhaust? sputtering in cold when you start in a.m?
Where do you get this 02 simulator????
Very interested.
Russ
[Modified by itr--779, 8:17 AM 4/15/2002]
Old Apr 15, 2002 | 07:41 AM
onyx00's Avatar
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (itr--779)
Everything else seems fine. I know originally awhile ago I was running way rich, but got V-AFC installed and had dyno tunning done and they clean it up a lot.
I will check the plugs today, and take a look under the car.
I reset the MIL using the reset prodecure and nothing yet after a full day of driving, so I will let you guys know.
Old Apr 15, 2002 | 08:49 AM
Malice's Avatar
New User
my friends Si had the same problem. He took it the dealer and said the o2 sensor went bad. this was after we put in his itr intake cam. i think its a bullshit code!! obd2
Old Apr 15, 2002 | 09:07 AM
Eeepers's Avatar
New User
http://www.diabloautosports.com/prod...198&PHPSESSID=
Try this link for the O2 simulator.
onyx, let us know if your light comes back on even after tuning. Mine still came back on.
Old Apr 15, 2002 | 09:29 AM
itr--779's Avatar
New User
Anyone ever tried this emmulator?
how well does it work?
One more thing where does this thing wire in? not at the back of the computer under the kickplate on passenger side does it?
thats bad news to fool around in there let me tell you.
I've had nightmares with having to straighten out minute wiring issues back there.
its a dog to troubleshoot.
[Modified by itr--779, 10:31 AM 4/15/2002]
Old Apr 15, 2002 | 08:16 PM
Eeepers's Avatar
New User
Its supposed to splice in at the 2nd o2 sensor after the cat.
Old Apr 16, 2002 | 08:17 AM
Black R's Avatar
25 Year Member
ditto.
**** THE EARTH!
Old Apr 16, 2002 | 08:23 AM
Austin's Avatar
The person that built that O2 emulator is a local and I have met him...he's also a member of the board. It works and I'm know for a fact that there are quite a few people that are running around with it locally that are very happy with it.
Here are a couple of other items from him:
Innovator of the JRSC electronic boost controller
J&S audible alarm
Austin - have the J&S Audible alarm, and am quite happy with it.
Old Apr 16, 2002 | 09:04 AM
itr--779's Avatar
New User
Eeepers..
From the picture it looks like a box like hondata or a field vtec controller.
How would that fit in the spot for the o2?
How does it mount?
Does anyone have a better picture?
Old Apr 16, 2002 | 09:13 AM
Austin's Avatar
It's only a couple of inches big...maybe a 2 X 2 X .5" and you would connect it in at the ecu.
Austin
Old Apr 16, 2002 | 11:31 AM
Eeepers's Avatar
New User
Default Re: Check Engine Light Code 67, AGAIN, Need Help! (Austin)
J&S audible alarm
Austin, could you give me this persons email address or user name, I would really appreciate it.
Thanks.
Old Apr 16, 2002 | 12:04 PM
Austin's Avatar
Thanks.
IM sent
Old Apr 16, 2002 | 01:00 PM
AzianAvenger's Avatar
New User
I ran with the code 67 for almost two years. I put on a 2 1/2 test pipe with my turbo setup and my ecu didnt like it.
Well until I get a Hondata, I am just going to have to deal with the check engine light. I really don't notice any performance differences that will make me want to reset the ecu everyday. But then again I was doing 10psi of boost and was not naturally aspirated.
Oh well... I got other problems to worry about like my blown #4. I can't wait for my block to come back from Golden Eagle...
-AzianAvenger
P.S. - My motor lasted of 20,000 hard boosting miles. I personally think bad gas was the culprit because she was running strong for awhile. 205 compression across the board after 18,000 miles of turbo.
Another_Teg_Owner
Dec 15, 2003 11:11 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
DelsolVtec18
Sep 6, 2001 01:11 AM
